hey guys. i brought the car back from leicester the other day, went fine, no problems at all. The last couple of days the cars been burning some oil, which i think is down to the fact that the rocker cover gasket has been tightened down too much, which has split the gasket, oils been getting into the exhaust manifold and burning. There is also a leak from the thermostat housing gasket, which has created alot of dry rust type residue, now, heres the problem. Me and flappyplasticbits have worked on the car, taken all the nessescary bits off. When we come to the thermostat housing, we see that some kind of instant gasket has been used. Also on inspection the gasket around the edge has peeled away, possibly causing this leak. We try to undo the bolts holding it on (u know, the 3 bolts in a triangular formation). They seemed to budge, however its only now, on my own, after trying to losen them off a bit more, that they have sheered in two. I have managed to get the top half of the housing off, as there is no thread on the top of the bolts, but the lower half is stuck fast. Now i know i could just drill them out, and re-tap the thread, but this is cast iron, and i need a UF tap and die set too. Is there any other way i can remove these "studs" that are left in the head?
Im very annoyed, as when i went over the car head to toe everything seemed fine, now i have the car back at home, all the bits seem to be going wrong or leaking. GRR
If anyone can help my situation, please give me a PM or email.
Thanks alot people, hope you can give me some advice.
James
