until about 3 days later I started to notice some oil seaping from the clutch cover seam.
But I didn't have any out the hole in the bottom with the cotter pin in it.
So I was thinking the worse-that I had damaged the seal during the install, but was hoping for the best...that it would stop on it's own.
Well it didn't and I really got aggrevated since I hate motors that leak.
So I yanked the motor and removed the flywheel and clutch.
I saw no evidence of a leak around the seal.
It wasn't even wet.
So I looked at the gear and the crank.
You can see where the seal rides on the gear.
and the holes that lead to the crank.
These are so as it spins the oil that runs between the crank and the gear will be slung back into the motor.
But, what if all of it doesn't get slung out?
Then it goes past the outer bushing in the gear and out past the splines.
At the end is the flywheel that also has holes on the inside to allow the oil to sling out past the clutch.
This keeps the oil off the clutch disc itself.
You can see a small ring of oil where the diaghram contacts the flywheel.
So now that I know how it's supposed to work....
What can you do to keep it from going out to the end of the shaft?
I see no seal and no mention of a sealant during install.
I measured the crank at 1.500" and the gear at 1.506"
So is it just a matter of the bushing at .006" clearance being too worn?
Maybe just clearancing/cleaning the first set of holes to ensure good easy flow for the oil to return to the motor?
Any suggestions before i drop this back in today?
