bullet mirrors
Posted 04 April 2005 - 08:51 PM
Posted 04 April 2005 - 09:04 PM
standard fit are cool- just bolt them on
non standard........ not cool i fitted some once but the finish was not cool because the plastic piece of C**p they supplyed to mount them cracked very easily. just be very carefull mate.
Posted 04 April 2005 - 09:57 PM
the way i ended up doing it, was i had to drill extra holes on the inner lip of the door, where i wanted one of the bolts to go through, if you can find then i suggest you get posi drive m6 screws to fit, at least for the front screws on each mirror, you can get away with m6 X 15mm long normal screw for the rear bolt, dont expect to see much out of the passenger mirror unless you put it realy high up on the door...
mine are on for show on legal reasons only, i never use then to see whats behind me
hope this helps
Posted 04 April 2005 - 09:59 PM
Going too fast for anything to be coming up behind thenI never use then to see whats behind me
Posted 04 April 2005 - 10:08 PM
in doing this it also rases the mirror up so that you can use it and saves drilling holes in the doors .
Posted 05 April 2005 - 07:37 AM
Posted 05 April 2005 - 04:03 PM
:grin:
Posted 05 April 2005 - 11:32 PM
I put mine at an angle because otherwise I couldnt see bugger all out of them!
<|Ben|>
Posted 05 April 2005 - 11:35 PM
Posted 06 April 2005 - 08:15 PM
Posted 06 April 2005 - 09:23 PM
I intend to buy some i can see out of at the next show (i think a good mirror will be a MUST on the German autobahns)
but if you must fit them
remove the chrome strips at the top of the door (inner and outer)wind the window down , use small bolts and fit them to a ring-spanner using a bit of dum-dum , if you cant find dum-dum , try blue-tac or plasticine , its fiddley but possable
Posted 07 April 2005 - 11:50 AM
They do look the dogs danglies also.
http://www.minisport...lh-product.html
The adjustable ones look the best for the job, I just hope they are straight replacements, as I aint drilling any extra holes in the car.
Posted 07 April 2005 - 12:08 PM
