hi all,
I have finally got round to plumbing in the cooling system and i do not have a bypass hose, now i understand that by drilling the thermostat it will allow for a little water to flow so i dont get hot spots before the thermostat opens up, my question is, how many holes and how big. i have tried searching but cannot find anything specifc,
thanks in advancve
Drilling The Thermostat
robbo
, Aug 19 2008 05:59 PM
4 replies to this topic
Posted 19 August 2008 - 05:59 PM
Posted 19 August 2008 - 06:34 PM
6 or 8, about a 5mm or 6mm hole.
I did eight 5mm, works nicely
Edited by Sammy D, 19 August 2008 - 06:36 PM.
Posted 19 August 2008 - 09:59 PM
cheers for the reply - do i really need that many, ive read a couple will do?
Posted 20 August 2008 - 09:36 AM
Ive not had much luck with holes in my thermostat. I drilled three at 4mm and it really did take an age to heat up; especially in the autumn, winter time. No doubt leading to increased engine wear and fuel use; so ive not got just one hole, and it heats up quite well.
Posted 20 August 2008 - 09:49 AM
It's easier to add them than take them away. 4 x 5mm holes would be about the same as a 10mm hole, which I'd guess is about the bore the original bypass.
