Rod Select Pin Removal - Attached To Gearbox
16 replies to this topic
#1 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 23 August 2008 - 06:31 PM
Haven't got my haynes at mo' as its being lent out so cant look up, having trouble removing one of the pins either the one you see in the picture or the other one near the bottom of same round casing.
Got a drive pin punch set already but neither one of these pins are budging, am I missing something simple here to get these out?
Any tips aswell as swearing at it aint helping much
;D
Edited by Kam, 29 December 2009 - 10:26 PM.
#2 Adcuz
Adcuz
  • 843 posts
Posted 23 August 2008 - 06:32 PM
Having the same problem, I await to see what the gurus have to say. ;D
#3 fishey798
fishey798
  • 562 posts
  • Local Club: Mini Rebels
Posted 23 August 2008 - 06:33 PM
They should just knock out.
#4 Beats
Beats
  • 353 posts
Select reverse and give it a good whack. If your drift isn't the correct size try the flat end of a drill bit, about 5mm I think.
#5 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 23 August 2008 - 06:34 PM
It helps if you use a piece of wood or something to keep the rod fixed whilst you're going at it with the roll pin punch. It looks like you've got it set about right (gearbox in reverse?).
#6 Kam
Kam
  • 4,140 posts
Posted 23 August 2008 - 06:38 PM
Yeah was told select reverse so the pin shows more
So am I right, just hit it and drive it through, its being stubborn big time!
#7 Beats
Beats
  • 353 posts
Posted 23 August 2008 - 06:40 PM
Yes, just use the fbh tool.
#8 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Yes, but using something to keep the rod steady helps. Otherwise it just bounces and you don't get enough force on the roll pin.
#9 Sammy D
Sammy D
  • 977 posts
Posted 23 August 2008 - 06:43 PM
I made a punch that was perfect from a good quality tent peg by cutting the point off it. Works a treat.
Your just going to have to keep trying, it will come out!
#10 Beats
Beats
  • 353 posts
Posted 23 August 2008 - 06:45 PM
I purchased the punch tool from minispares in the end.
#11 Kam
Kam
  • 4,140 posts
Posted 23 August 2008 - 06:50 PM
Sorry mate whats fbh? Is this the minispares punch tool?, because the drive pin set I have is the right size, I just didnt know if I was doing something wrong.
#12 Adcuz
Adcuz
  • 843 posts
Posted 23 August 2008 - 06:52 PM
F***ing
Big
Hammer
;D
#13 Guest_iansmini_*
Guest_iansmini_*
  • Guests
Posted 23 August 2008 - 06:56 PM
May not be the wisest idea but last time I had to remove my roll pin, I used the little flame torch thingy to apply a bit of heat.
#14 Kam
Kam
  • 4,140 posts
Posted 23 August 2008 - 07:00 PM
F***ing
Big
Hammer
Oh right oops my bad! :thumbsup:
Now I feel like a
F***ing
Big
Helmet!
;D
#15 Pauly
Pauly
  • 4,213 posts
Posted 23 August 2008 - 07:06 PM
Dont be scared to give it a good wack ;D.
The one to remove is the one nearest the box, as its more accessable and more sterdy that end.
Paul.
Edited by Pauly, 23 August 2008 - 07:07 PM.
