Alternator Problems
Posted 26 August 2008 - 06:52 PM
After a few weeks, my alternator started producing 9.89 to 11.98 Volts..
To try to fix this problem, i have changed teh following: Regulator ; diode bridge ; brushes ; fuses .
Yet the voltage hasnt changed.
What solutions are there ?
by the way.. i have checked that the diodes are correctly working, regulator grounds correctly. and the between the diobes resistivity
i have also checked the: dashboard ; starter motor; fuses; distributer cap ; lights; and battery. for fault that could be causing the problem, but they all work correctly..
the car is negativily grounded
Posted 26 August 2008 - 07:59 PM
Posted 26 August 2008 - 08:01 PM
Posted 26 August 2008 - 08:30 PM
Have you checked the drive belt?
Yeap the drive belt is fine...
Posted 27 August 2008 - 07:08 AM
is it possible that my alternator is broke ful stops ?
Posted 27 August 2008 - 08:37 AM
Edited by Major Burkenshaw, 27 August 2008 - 08:37 AM.
Posted 27 August 2008 - 09:47 AM
Its possible that one of the windings have gone open circuit, can you see any physical damage to them? If you stip the alternator down you could test the continuity of the three windings where the connect to the rectifier.
yeah it looks like the windings are broken,
thanks for the help
Posted 27 August 2008 - 01:08 PM
You said you followed the standard information in Haynes and elsewhere when you did the conversion. I wasn't aware that Haynes discussed this at all. When you replace the dynamo there are indeed several ways to convert the wiring but I'll summarize it succinctly below. See if this matches in practice what you achieved with your conversion.
At the old dynamo control box, remove the three heavy gauge wires and join them together.
Again at the control box, remove the two small gauge wires and join them. (Do not use the black earth wire).
Remove the dynamo and install the alternator.
Take the small dynamo wire and place it on the small alternator terminal.
Take the large dynamo wire and place it on one of the large alternator terminals.
If you want, run a second large wire from the remaining large alternator terminal to the battery side of the starter solenoid.
(You may have spliced the wires together to achieve this... or done the more cosmetic approach of modifying an old control box to act as a junction to connect the wires. The result is the same, it's just a matter of appearance.)
As has been discussed in several recent threads, the Lucas alternator requires that the charge light be working. You must observe the following:
Key off, engine off = warning light off
Key on, engine off = warning light on
Key on, engine on = warning light off
If you are seeing proper warning light operation and if in practice your wiring matches what I describe above, take the alternator to a shop for testing. Also keep in mind that batteries do not last forever. If your battery is more than three years old, consider it as another possible explanation for the problem.
Posted 27 August 2008 - 03:35 PM
I worked of a circuit diagram in teh haynes manual which shows teh wiring for alternator..
Teh ign-light works just as u said..
thanks..
