1:3:1 Rockers
4 replies to this topic
#1 087dave
087dave
  • 952 posts
Posted 12 October 2008 - 12:13 PM
Hi out there do 1:3:1 roller tip rockers work well on a 998 do there give high lift? or would you have to use them with a hot cam like a sw5 cherrs!!!!!!!!!
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 12 October 2008 - 12:19 PM
big lift on a 998 kills power
if your after removing so power i would suggest fitting a 2 inch exhaust and some 8x13 wheels as well :D
#3 mike.
mike.
  • 6,176 posts
Posted 12 October 2008 - 12:28 PM
Small bores can benifit massively from the right cam when coupled with a ported head and usual stage 1 kit.
IMO i think you'd be wasting your money on a set of roller tip rockers, especially 1:3:1 ratio ones. Any hike in power will be pretty small - Barely noticable i imagine.
In terms of BHP for your buck you'd be better getting a new camshaft (kent 276, 286 and MG metro cams work well on 998s) or a stage one kit if you haven't got one already.
Bare in mind most mods you do will require the car to be set up on a rolling road afterwards to set the timing, needle amd mixture to suit for maximum power and smoothness.
#4 lorry
lorry
  • 249 posts
Posted 12 October 2008 - 12:42 PM
The original rockers are about 1.29 or something like that so there is not much extra lift. The roller tips may give smoother running though
#5 mike.
mike.
  • 6,176 posts
Posted 12 October 2008 - 12:44 PM
Standard rockers are just under 1:25 ratio i think...
