Oil Sump Plug Seized
Posted 17 October 2008 - 05:48 PM
Posted 17 October 2008 - 06:01 PM
Posted 17 October 2008 - 06:11 PM
EXTREMELY carefully grind the six sides of the plug back to six sides. Obviously they would be the next size down
or
Weld the largest nut possible onto the current sump plug and use that to get the old one off.
Obviously both methods would destroy your old sump plug but it would give you an excuse to buy a nice new one with the extended magnetic bit to catch all the metal particles from your oil?
Posted 17 October 2008 - 06:24 PM
Posted 18 October 2008 - 02:37 PM
warm the gearbox casing up around the bolt and then spray the bolt with freeze spray. should come out nice and easy
When you say freeze spray, do you mean standard anti-freeze?
Posted 18 October 2008 - 07:17 PM
Posted 18 October 2008 - 08:22 PM
Is the bolt locked solid or is it just spinning in the hole... ??
Posted 18 October 2008 - 08:59 PM
Posted 20 October 2008 - 10:03 PM
The loctite freeze spray is really good, also has a 'de rusting' agent in it, ok not so brilliant for aluminium but excellent for suborn exhaust bolts..
Posted 21 October 2008 - 11:43 AM
