Spi Engine Rebuild And Mod
3 replies to this topic
#1 mark cottam
mark cottam
  • 33 posts
  • Local Club: n/a
Posted 24 October 2008 - 09:21 AM
hi all, I'm currently in the process of rebuilding my 92' SPI engine and was just wondering if anyone could give me an idea of the best modifications to give it. So far I've decided on the following: crankshaft re-grind with lightening and balance and new bearings, new piston rings, minisport camshaft kit, vernier duplex chain timing gears, straight cut drop gears, LCB manifold, K&N induction kit, cylinder head refurb.
If anyone could let me know if these are appropriate or not and if there's anything better i would be grateful!
Also, when rebuilding an SPI, the timing will obviously be reset. Will this mean an ECU reprogram??
cheers. mark
#2 duncancallum
duncancallum
  • 533 posts
Posted 24 October 2008 - 10:18 AM
I wouldnt bother with a minisport cam i used a 274i in mine
mines:
Mg metro head cleaned ports and chambers
1293
centre main strap
balanced and slightly lightened
274i cam
vernier pulley
standard box and drops(centre pick up)
3.2 diff(comp diff pin)
k&n filter
maniflow lcb
maniflow 2 box system
Edited by duncancallum, 24 October 2008 - 11:07 AM.
#3 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 24 October 2008 - 10:30 AM
cantre oil pick up.
modified carb/spacer/manifold, (as per Vizard).
Dave
#4 icklemini
icklemini
  • 2,982 posts
Posted 24 October 2008 - 06:04 PM
dont bother with the straight cut drops... spend the money on a modified head and sw5 cam.
yes to a central pickup pipe...
I'm involved with the mighty minis, the spec of the class b cars (supers), allow a number of modifications that will work ok with the standard 1.3i cooper ECU..
altering the timing on a SPi is tricky: you either have to go megajolt, or you can alter the reluctor ring on the flywheel...
fundamentally though, you can mod it as per above, and get a good improvement before going into the cost and hassle of messing with ECUs...
