From speaking to people I found out that a leaking windscreen is quite common on mini's or maybe its just my car. I replaced my windscreen when I first got the car with a new windscreen rubber but found out that it was leaking from both bottom corners so out came the kitchen towel n I have to stuff it in the corners to soak up the water.
A few weeks ago I had the wind screen taken out again and had sealant put around the inside of the rubber, where the glass sits. I was told it should hopefully push the glass out a little and stop the leak.
Unfortunately this did not work either so I have had to go back to the kitchen towel solution for now
I was wondering if any one new of anything else I could do to try and stop the leak. I'm unsure if it is to do with the rubber maybe being a pattern part so not fitting as well as it should but didn't think you could get heritage or original window rubbers.
Any suggestion would be extremely appreciated as at the minute I am having to dry my nice new carpet out under neither the floor pan every time it rains
Many Thanks
Aaron
