Oil Leak Quick Fix?
11 replies to this topic
#1 Sammy D
Sammy D
  • 977 posts
Posted 28 October 2008 - 05:42 PM
Just noticed that I'm leaking a considerable amount of oil from between the block and gearbox. Obviously it's only happening when it's running and warm, but it's a pain.
I only had the engine out of the car and apart less than a week ago! I used hylomar +gasket and had no leaking problems at all, this time I used gasket + silicone gasket sealant and it's shocking!
I really don't fancy pulling the lump AGAIN! Is there something I can smoosh around the join to hold the oil in?
I know it's a bodge!
#2 T.Harper
T.Harper
  • 714 posts
Posted 28 October 2008 - 05:55 PM
Did you check the O ring from oil pickup to block?
#3 Sammy D
Sammy D
  • 977 posts
Posted 28 October 2008 - 07:46 PM
Yeah changed that, it's leaking at the front of the engine though.
Is there some kind of paste that I can chuck on?
#4 Ethel
  • 26,046 posts
Posted 28 October 2008 - 08:03 PM
do you mean the front of the engine (timing gear end) or the front of the car? could be the c shaped crank seal if the former.
#5 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 28 October 2008 - 08:08 PM
put in back to front? real bummer the motor will have to come out. or the timing chain and back plate removed so you can try and replace it in sit. ouch.
you could boil up a pair of old socks add a sack of plaster pour that in remove the oil first! :D
#6 Sammy D
Sammy D
  • 977 posts
Posted 28 October 2008 - 08:09 PM
Sorry yeah I mean the front as in the front of the car, not the "waterpump end front".
edit: yeah I replaced the half moon seal :D
Edited by Sammy D, 28 October 2008 - 08:10 PM.
#7 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 28 October 2008 - 08:18 PM
can you see exactly the point at which the oil leaves the motor?
I had this once oil at the bottom of the box after a long look it was coming out of the bung in the oil gallery running downthe motor.
you dont like the plaster idea?
#8 Sammy D
Sammy D
  • 977 posts
Posted 28 October 2008 - 11:34 PM
What did you mean about the plaster?
I couldnt figure out how boiling socks and plaster could do anything but make a huge mess.
#9 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 29 October 2008 - 09:26 AM
Are the bolts tight holding engine/gearbox together! just checking!
EDIT; IF bolts are tight i think it`s engine removal time to be honest!
Edited by mini_kel, 29 October 2008 - 09:28 AM.
#10 Sammy D
Sammy D
  • 977 posts
Posted 29 October 2008 - 09:52 AM
Yeah, FT.
Might leave it for a bit, and try and see how bad it is before I consider taking it out AGAIN! Although to be fair it is only a days job.
#11 nicksuth
nicksuth
  • 1,631 posts
Posted 29 October 2008 - 10:02 AM
Someone was telling me the other day that you can get an engine oil additive which will seal minor leaks? A bit like the equivelant to Radweld for the cooling system? Anyone heard of it?
#12 Sammy D
Sammy D
  • 977 posts
Posted 30 October 2008 - 12:44 AM
True fact, yes. I've seen it in Hellfrauds.
I read the back and it said that it wont affect the engines performance, but I'm not so sure! I don't fancy sticky oil.
