Home-made Weather Shield?
13 replies to this topic
#1 MiniDick
MiniDick
  • 597 posts
Posted 30 October 2008 - 07:36 PM
I'm looking to make my own weather shield, has anyone done it? Are there any templates available for one?
#2 captainjack15
captainjack15
  • 3,925 posts
Posted 30 October 2008 - 07:39 PM
This would go down a treat :dontgetit:
to be honest shouldn't be too difficult should it? You could just make it out of acrylic of something?? As-long as you get some templates, if you get them can you tell me please ;D
Thanks very much:D
#3 Asphalt
Asphalt
  • 2,173 posts
Posted 30 October 2008 - 07:45 PM
Dustpan with cut-off handle ;D
Available in all colors & cheap.
Cheers,
Jan
PS: I'm running silicone leads & unworn cap/rotor.
No worries even in heavy storm & 8" water on the road :dontgetit:
Edited by Asphalt, 30 October 2008 - 07:47 PM.
#4 markaboot
markaboot
  • 723 posts
i've seen a couple of people using car mats cut to shape.
#5 MiniDick
MiniDick
  • 597 posts
Posted 30 October 2008 - 07:46 PM
That could well be my mission for the weekend.....Just wondered if anyone has done it. Shouldn't be too difficult, should it? I mean it's only a sheet of plastic. I've seen them going for £50 on thiefbay and £22 on Minispares.
An old bloke at work said he had a cover thing which fitted over the dizzy....accurate description.....
Edited by MiniDick, 30 October 2008 - 07:49 PM.
#6 kooky
kooky
  • 133 posts
Posted 30 October 2008 - 07:49 PM
Just make sure you get heat resistant plastic or it could be messy !!!
#7 Asphalt
Asphalt
  • 2,173 posts
Posted 30 October 2008 - 08:00 PM
Early minis had sometimes a spacial rubber-cover which fit over the leads & cap + another covering the coil.
Don't know if they fit 'modern' dizzys and if they are still availble...?
I've seen people using a rubber glove and some cable ties.
Well... Not something for Concorso d'Eleganza but pretty clever ;D :P
Heat resistant?
Most plastic will cope with temperatures over 60° :dontgetit:
I've never checked it - but I don't think that there's more than 60° around the engine, where the shield sits, ever :rolleyes:
Cheers,
Jan
Edited by Asphalt, 30 October 2008 - 08:03 PM.
#8 captainjack15
captainjack15
  • 3,925 posts
Posted 30 October 2008 - 08:03 PM
Note taken ;D
#9 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 30 October 2008 - 08:33 PM
the ignition shields are complete over kill, all you need is a well placed square of plastic behind the grille ;D
#10 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 30 October 2008 - 08:41 PM
I find the rubber glove over the dizzy works the best! ;D I bought a pack of 4 of those flexible chopping boards from Wilko and cable tied one of them onto the back of the grille! Took a little bit of cutting, but does the job!
#11 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 30 October 2008 - 08:51 PM
well why not go the whole hog, if your gonna shield it.... shield it ;D
#12 MiniDick
MiniDick
  • 597 posts
Posted 30 October 2008 - 09:41 PM
I like the Wilko chopping board idea! CHEAP - Just the way I like it ;D
#13 Globule
Globule
  • 1,134 posts
Posted 30 October 2008 - 09:59 PM
Mine still cut out with one of these ignition shields fitted (i was driving rather childishly through puddles though) so its not 100% watertight!
#14 1984mini25
1984mini25
  • 8,784 posts
Posted 30 October 2008 - 10:12 PM
Mine being an 80's model came with a factory fitted small square splash guard that’s mounted to the back of the front pale to cover the dizzy, which seams to work. Although it's the coil I’m having problems with, as even with a length of old door seal attached to the inside lip of the bonnet to try and keep the rain out and stop it rattling, the coil still gets soaked causing all sorts of earthling/misfiring problems.
I’ve got a spare larger weather shield from the later 90’s minis, but I’m looking at using that as a template to make a mush larger one for the project as the inner wings have been removed for the flip front and the engine is more exposed.
