Engine Identification Challange
7 replies to this topic
#1 Pitcrew6464
Pitcrew6464
  • 1,673 posts
Posted 03 November 2008 - 07:12 PM
Hi could anyone help ive searched and searchd but struggling to identify this engine:
left hand side of the engine is 1100, with 1811 just below. In the middle is stamped M O W O G and on the right hand side 12A 497 W M C 237588
any clues
#2 Jammy
Jammy
  • 25,397 posts
Posted 03 November 2008 - 07:14 PM
There should be a ID tag on a flat bit just behind where the alternator is/would be.
#3 Pitcrew6464
Pitcrew6464
  • 1,673 posts
Posted 03 November 2008 - 08:06 PM
are none of these numbers any good?
#4 jplonie
jplonie
  • 447 posts
  • Local Club: www.lcmoc.com
Posted 03 November 2008 - 08:32 PM
The 12A means a 1275cc (post 1990).
Is there nothing nelse after the 12A? eg:
12A/2A (Carb type)
12A/2B (Carb and Catalyst)
12A/2D (SPi (throttle body injection))
J
#5 Pitcrew6464
Pitcrew6464
  • 1,673 posts
Posted 03 November 2008 - 08:34 PM
12a497, but it has the removable covers on back of block with breather coming out.
Edited by Pitcrew6464, 03 November 2008 - 08:35 PM.
#6 jplonie
jplonie
  • 447 posts
Posted 03 November 2008 - 08:44 PM
Sorry not sure apart from the 12A part.
MOWOG as mentioned above did parts for A series engines (there is a MOWOG inlet manifold on ebay now) not sure if they did the full engines .
EDIT:
Just seen this
http://cgi.ebay.co.u...-...A1|240:1318
J
Edited by jplonie, 03 November 2008 - 08:45 PM.
#7 Asphalt
Asphalt
  • 2,173 posts
Posted 03 November 2008 - 10:11 PM
MOWOG means "MOris WOlseley Garages" and it's on almost anything of the engine as 'they' made all the engines & stuff.
12A497 is a number on the back of the block and - and as far as I know refers to a 'smal-block' engine.
WMC237588 - don't know...
What is the head's cast number?
(Take off the rocker cover)
Edited by Asphalt, 03 November 2008 - 10:14 PM.
#8 62S
62S
  • 1,244 posts
  • Local Club: You must be joking!
Posted 04 November 2008 - 07:48 PM
12A 497 is not the engine number, it is the block casting number of the commonised A series small bore block - most likely to be a 998 (could be a 998 Cooper but probably isn't) or 1098 engine and if it has an 1100 tag on the back then 1098 unless someone has changed the internals.
