A+ head to an A-series...
Posted 18 July 2005 - 05:29 PM
If i buy a head from an a+ engine is there a simple job of getting it modified and dropped on, or will the a+ head simply not fit a standard a-series?
Plus will a 11 stud head fit on a normal 9 stud engine, without putting extra studs in?
Posted 19 July 2005 - 07:51 AM
You can make up an alternative to the bypass hose. I've got a take off under the thermostat housing (like a Metro one) and that feeds back to the bottom hose to give the bypass.
The A+ head will fit OK. I don't think any of the A+ heads were 11 stud. Certainly the MG Metro wasn't. But an 11 stud head will fit a 9 stud block OK.
Posted 19 July 2005 - 09:03 AM
Posted 19 July 2005 - 09:13 AM
Posted 19 July 2005 - 11:51 AM
Posted 19 July 2005 - 12:01 PM
Posted 19 July 2005 - 12:24 PM
that needs skimming right?
I assumed that was a 1275 head, is it better or worse than the 940?
what exactly is pocketing the block? can i do it myself or do i need to get the block out?
and I have experience of bypass hose hell a friend of mines midget was blowing bypass hoses on average of three a week before he got the problem sorted
Posted 19 July 2005 - 02:20 PM
EDIT:
Sorry Matt... didn't mean to ignore your question. The 12G940 is a 1275 head. Pocketing the block is making a little spotface/flat-bottom counterbore on the top surface of the block to clear the valves when the larger bore cylinder head is installed. It's best done by a machine shop (isn't your word for that "engineering works"?). The depth of the pockets must clear the heads of the valves taking into account whether or not you're running a high-lift cam or something other than standard ratio rocker arms.
Edited by dklawson, 19 July 2005 - 02:24 PM.
Posted 19 July 2005 - 03:30 PM
I'm thinking that I just want some extra power from my 1000 but i'm not really keen on removing the engine, as my plan is to get my car on the road and run it a bit while building up somthing that'll blow your pants off, so I don't want to have to whip the block out and get it machined just to gain a bit more power as thewhole unit will be out in 6 months.
so with that in mind do people think the 9 stud 12g295 will be the more viable head for my pimpmobile?
or is there no way around this with out a load of machining?
Posted 19 July 2005 - 06:25 PM
Posted 19 July 2005 - 06:37 PM
Posted 20 July 2005 - 12:24 PM
6 holes in the stat and it will NEVER heat up ! 2 x 1/8" is fine. Indeed in winter I have a higher rated stat with NO holes - makes for a great heater !
Posted 21 July 2005 - 08:58 AM
Posted 21 July 2005 - 10:15 AM
Oh and if you drill 6 holes in the stat it'll never get warm on cold days (as roy said) If you're gonna drill holes you only need to let the same amount of water through as the by-pass or better still don't bother and just leave the heater tap open all the time or if you can keep the by-pass hose and just fit some decent hose to it.
The 295 will need skimming a fair bit to get the compression right but will be less messing than pocketing the block, also you may need to file a bit off the top pulley as it can catch the bottom of the head but best just to try it and see if it fits.
