Sony Giga Panel
8 replies to this topic
#1 latestarter2
latestarter2
  • 124 posts
  • Local Club: Blakehill Minis
Posted 04 November 2008 - 10:23 PM
Title self explanatory i guess. I wired in my Sony1giga panel head unit and it came on the display as "failure" which meant the speakers were wired round the wrong way. So I changed them about but now it reads the tracks ive downloaded onto it and then keeps cutting out?
Also when I switch offf the ignition it cancels all the memory evertime.
Any suggestions?
#2 lorry
lorry
  • 249 posts
Posted 06 November 2008 - 09:54 AM
Check your earth is good enough and check for memory wire
#3 lowandslow
lowandslow
  • 359 posts
  • Local Club: east coast mini club
Posted 06 November 2008 - 03:06 PM
top head unit i've got one of these.
i'd have a look at your + wiring also does it cut out when you turn it up? if so it'll be your batt isn't up to the job, they have a safety cut out.
can you take a pic of how you have wired it up?
Edited by lowandslow, 06 November 2008 - 03:07 PM.
#4 latestarter2
latestarter2
  • 124 posts
Posted 05 April 2009 - 03:18 PM
I darent take a pic as its a bit messy but Ive used the plug and play socket adaptors .
As you said it cuts out when the volume and bass goes up so in what way do you mean the battery isnt up to the job?..What battery would you recommend i switch to run my head unit?
cheers
#5 lorry
lorry
  • 249 posts
Posted 06 April 2009 - 10:19 AM
If the plug and play harness you used is the ones that's like the metro plugs then it might not have a permenant feed. Because it may be like my mini in that the original radio was a tape player with manual tune, so there was no need for a permenant for saving stations.
#6 davegreory42
davegreory42
  • 89 posts
Posted 07 April 2009 - 03:20 PM
mine does exactly the same thing. when its been driven for a long time it gets more and more frequent until eventually it won't turn on at all. its an alpine head unit, forgotten the model no. when i rebuilt the engine we fitted a more powerful alternator and that has made no difference. about a week ago i bought a new battery and so far so good. i guess only time will tell. at first it was unbelievably annoying but in the end i gave up. nice to have the radio back though
#7 latestarter2
latestarter2
  • 124 posts
Posted 08 April 2009 - 07:05 PM
Well fingers crossed im stripping the wiring out a completely re - doing it tomorrow.. i discovered the earth cable was broken yesterday so perhaps it'll sort the problem. Ive got a 50amp alternator so that should be pumping enough juice into the battery just depends if the battery is pumping it back out the other end i suppose?
#8 latestarter2
latestarter2
  • 124 posts
Posted 09 April 2009 - 11:12 AM
ok..so now it doesnt cut out but now there's a buzz through the speakers for a very short while when i switch the ignition off and the head unit is also showing "failure" when i switch off which suggests the speakers arent wired in properly but they're done + to + etc so now im a bit confused?
#9 davegreory42
davegreory42
  • 89 posts
Posted 10 April 2009 - 04:25 PM
very strange, mine never did any of that, it just wouldn't turn on. i dont know what to suggest to be honest, i tried evrything to figure out what was wrong with mine and still havent worked it out, it still hasn't played up since i changed the battery though.
