He has supplied the pistons pre-fitted to the con-rods. At first glance they looked like 1380 pistons but wont fit into a 1380 block i have prepped (offset bored and honed) , yet the top of the piston when turned upside down will slide into the bore.
I took several measurements took with a digital vernier and pictures of the piston and was wondering if people could help me out as to what size the block should be, and what the pistons are out of.
Ring size (starting with top one)
0.060"
0.074"
Oil Ring
0.150"
Piston diameter (TOP + BOTTOM)
2.890"
2.900"
Pin to Piston Crown
1.090"
Top Ring to Crown
0.276"
Here are some of the pictures i took of the pistons, they are flat top's and stamped on the top is the markings 'STD', 'ID10', 'R21' and a letter 'Z'
On the inside of the piston there is the AE logo and 'C89' and the number '413'
Piston top markings
Side view of the piston
AE and C89 stampings
413 stamping on the inside
Split skirt type piston???
The rings
Many thanks for your help
Adam
