Brake Bleed Nipples
Posted 08 November 2008 - 03:33 PM
Posted 08 November 2008 - 03:51 PM
going to bleed brakes as just nenewed all pipe work but the nipples have been trashed in the past. how do i remove these as mould grips just slip off and i want to mot it soon and iv spent to much lately on it and really dont want to have to bye new calipers
could you file two flats on to it and get an adjustable spanner on?
phil
Posted 08 November 2008 - 04:16 PM
get a crescent wrench ( the type that get tighter as you apply more pressure )
drill them out with a left handed drill ,this will get a grip on the nipple and sometimes can unscrew them
drill them out with a drill about 1 mm smaller than the nipple thread and re tap the hole once its all out ,you must be careful not to drill too deep and damage the seating face . run the drill at a slowish speed as nipples are slightly hardened ( this is why they break off ) and spray wd 40 on it as you drill
the best way is tale the caliper off the car ,clean out the brake fluid and get some heat into the nipple with a blow torch , when its hot too touch stand back and spray it with wd 40 ,this will smoke a lot and any gap opened up by heating will soak in the wd40 and free things off a bit wait until cool and try mole grips again ,try to tighten it a bit first then un tighten ,back an forth and it should free off easier
then buy some new bleed nipples and fit them with copper grease , make sure when youve bled the brakes to clean up and fluid around the nipple and slap a bit more grease over the nipple
Posted 08 November 2008 - 06:26 PM
Big wrenches will give you more leverage... but I'd still avoid a crescent wrench. Their jaws spring and are likely to round the nipple off again. It's also a bit harder to feel with things are failing if you use a big wrench. I'd stick with a big pair of vise-grips (mole grips) as they will bite into the nipple.
Posted 08 November 2008 - 06:31 PM
Posted 08 November 2008 - 06:34 PM
Posted 08 November 2008 - 08:41 PM
Regardless, start by taking the caliper off. I would certainly start with what was suggested by Maddogmcg and use progressively larger LEFT-HAND drill bits to drill down through the center of the broken nipple. Left-hand is important. There's a very good chance with the LH bits that towards the end, enough material will have been removed to relieve stress on the threads, the bit will "catch" and the broken part will back out on its own.
I strongly encourage you to try to avoid re-tapping the caliper if possible. If you must re-tap it, use only a very sharp bottoming tap. You don't want to enlarge the threads at all and you don't want to damage the seat in the bottom of the hole.
Once you do have the broken part out, there is a fix that was recommended to me that I have posted on every one of the broken bleed nipple threads. With the broken nipple out of the caliper, look at the hole in the bottom of the caliper. Find a steel ball from a ball bearing that is about twice (2 times) the diameter of the hole in the bottom of the nipple seat. Buy a new bleed nipple. Take the new bleed nipple and grind its point away until it has a completely flat face. Drop the ball down into the bleed nipple hole and follow it with the flat faced nipple. The flat faced nipple will drive the ball into the seat and close it. Loosening the nipple will allow the ball to lift up for normal brake bleeding.
The ball bearing fix will become important to you if you re-tap the caliper. The seat is machined concentric with the threads and the fit of the threads to the nipple is important. If you get slop in the threads or if the threads are off center... the conical point on the nipple will not close off the seat. The ball will.
Posted 09 November 2008 - 07:57 PM
