Lots Of Revs No Acceleration
Posted 08 November 2008 - 04:30 PM
Posted 08 November 2008 - 04:37 PM
Posted 08 November 2008 - 04:49 PM
Posted 08 November 2008 - 05:42 PM
For the last week or so when trying to get upto speed (mainly on the motorway) my revs will go really high but there will be very little to no acceleration
sounds like a slipping clutch...
I'm not sure if it's connected but I think my idle is a little high but only about 13-15, and a few times now after I have been for a drive turn the engine off and take the keys out the engine will keep going for a second or two and splutter to a stop.
its not connected to the slipping clutch problem..
revs to high can and lead to the engine running on as you describe...
have you tried turning the revs down?
Posted 08 November 2008 - 07:42 PM
Posted 08 November 2008 - 08:15 PM
Posted 08 November 2008 - 08:23 PM
Posted 08 November 2008 - 09:18 PM
high idle and over run = to far advanced, the more you advance it the more the idle will pick up and also over run
i reckon these are your problems, if not that my bad
Posted 25 November 2008 - 04:36 PM
Posted 25 November 2008 - 05:56 PM
Running on, pre ignition, pinking or what you like has another name that describes it pretty well - dieseling.
Basically something ignites the fuel air mix before the spark does. It could be a hot spot in the combustion chamber be it carbon, a valve or the spark plug itself. Just like a diesel engine the pressure and temperature ignites the fuel, if this is insufficiently before the piston reaches top dead centre the pressure in the cylinder will effectively be pushing against the direction of rotation and the temperature will shoot up as a consequence of the much higher pressure; that's what causes damage like melted pistons and burnt valves.
Lower grade petrol is more prone to dieseling as are high compression engines, like 10.5:1 MG Metro's, hence why an anti run on valve was fitted. Running on isn't likely to cause damage but it is indicative of an engine that could be prone to piston melting pre ignition.
It could be carbon build up in your engine or it could be the ignition timing. Sort your idle out first though because the fast idle could just mean that it's taking longer for the engine to slow to a stop.
