Year:1989/1990
Description of problem (please be as in depth as possible):Right just reconnected my new loom to the engine, everything back in right place(as far as i know!) Turned the key and there is a noise coming from the relay in the top left of the engine as you look at it(drivers side.I believe this to be the starter relay?.The noise is hard to descibe, its not a clicking noise but sounds like when you hit two live wires together, I've checked the connection and its pushed in as far as it goes. Is the relay knackered or does it sound like another problem?
Hope this sounds clear to you all.
Edited by padnic, 08 November 2008 - 07:35 PM.
