After i've degreased the casing how do i go about cleaning the oxidisation off?
Will engine laquer take to aluminium or will i need some primer?
Will i need to key the surface at all?
On a seperate note, is any primer needed on the cast iron engine block before the engine laquer is applied?
any help on this would be much appreciated because i'm stuck now
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/sideways.gif)
