From Inertia To Pre Engaged
3 replies to this topic
#1 MINI 1
MINI 1
    The Ginger One #2
  • 714 posts
  • Local Club: LCMOC
Posted 09 November 2008 - 07:12 PM
just fitted new engine into the car , the new starter motor is pre enaged . my 998 engine used a intertia type starter motor.
i would like to no how do i go about changing the wireing? so it suits a pre engaged starter motor.
ash
#2 Ru55boy
Ru55boy
  • 457 posts
Posted 09 November 2008 - 08:26 PM
I kept the solenoid from the inertia starter and used the existing wiring and connected it to the piggyback solenoid on the pre-engaged starter.
I swapped the wires on the terminals on the inertia solenoid.
Sorry for the small pic...
Attached File  Running002_x.jpg   126.55K   53 downloads
#3 MINI 1
MINI 1
    The Ginger One #2
  • 714 posts
  • Local Club: LCMOC
Posted 09 November 2008 - 09:25 PM
hi , no its fine thanks for getting me a picture.
Has anywon done the same thing , or slighty different and could explane?
thanks
ash
#4 Asphalt
Asphalt
  • 2,173 posts
Posted 09 November 2008 - 09:44 PM
You need exactly one short wire.
Either use a big cable shoe or file the connection smaler.
It doesn't matter to function.
Attached File  DSC00270.jpg   80.86K   22 downloads
You need a wire-bridge from were the big + cable (just the old one coming from the solenoid) attaches to the big cable shoe above/behind.
That's it. The starter gets engaged and the rest of the electrics stays untouched.
Works for over two years now...
Cheers,
Jan
Edited by Asphalt, 09 November 2008 - 09:46 PM.
