1275 (Non-S) Engine Build Query #2
7 replies to this topic
#1 minijazz
minijazz
  • 173 posts
Posted 09 November 2008 - 08:59 PM
Hi Groovers
I'm doing my first rebuild on a 1275. non S.
Could anyone have a look at the attached jpegs & tell me if the hole I have flagged up in red is meant to be there? Its at the timing end of the block. The end plate is not completely attached yet and the duplex timing gear is not attached- is there something between the end of the block & the end plate I have forgotten. I cant see anything in the moss or SC or minispares cats I have forgotten.
The timing gear and timing cover go onto this end- is this hole for oil to be thrown from by the oil thrower?
Sorry guys but I dont really know and dont want to norse it up.
cheers all
col
#2 nicksuth
nicksuth
  • 1,631 posts
Posted 09 November 2008 - 09:14 PM
I'm not sure but have a look at these?
http://www.somerford...fs/engines.html
There is an oil restrictor fitted somewhere.
#3 minijazz
minijazz
  • 173 posts
Posted 09 November 2008 - 09:51 PM
Hi
Thanks- still a little unsure!
Col
#4 mk1leg
mk1leg
  • 9,343 posts
Posted 09 November 2008 - 10:45 PM
As long as you have fitted gasket between block and plate first and that hole is for oil to flood gears and chain to keep it lubbed........... :P
#5 nicksuth
nicksuth
  • 1,631 posts
Posted 09 November 2008 - 10:47 PM
How does the oil drain back to the sump/gearbox?
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 10 November 2008 - 07:29 AM
Yes it's meant to be there...
#7 Kernal H
Kernal H
  • 746 posts
Posted 10 November 2008 - 09:24 AM
How does all the oil flow back into the engine/gear box?
#8 minijazz
minijazz
  • 173 posts
Posted 10 November 2008 - 08:45 PM
Hi
Many thanks
cheers col
