Roof lining fitting
15 replies to this topic
#1 soopercooper
soopercooper
  • 110 posts
Posted 20 July 2005 - 03:07 PM
I have my new Mk2 roof lining material from Newton commercial, and I've removed the roof from my mini - anyone got any tips for sucessful fitting of the new material? i.e. what order to do it in, what glue to use to stick it to the edges etc..
Any advice greatfully recieved, as I don't want to bugger it up!
#2 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 20 July 2005 - 03:33 PM
my best piece of advise is.... get someone else to do it! even professionals hate doing roof linings!
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 July 2005 - 03:55 PM
Roof linings are a complete pain in the ****..
1 get EVERYTHING out of the car, seats, windows doors, gearknob steering column and sepecially the handbrake..
you are going to have as much room to move as possible...
The last one I did too the best part of a week to get it right ( a couple of hours each evening ), but first, get some small bulldog clips or strong pegs ( you'll need a few)
then, after pushing the poles into the lining at the correct point connect them into the cant(?) rail from back to front, the right way up but leaning towards the back. then the first clip shoud be placed at the middle of the back (rear window) and the lining sdjusted so that the first rod id upright. then all the rest can be pulled up right and one clip placed at the middls in the front, this may take a few attempts but will mean the headlining is straight front to back and the poles are correctly situated...
you will then be able to complete the clipping of the front and back, again adjusting as necessary... You may then start on the sides, stretching the vinyl to form the correct shape, there may be a need to cut the lining around the "B" post.
Once all is clipped, sit in the car and look at it, look for strtch marks, mishapes etc as you will have to live with it when it has been glued...
ONLY when you are satisfied with the fit should you use glue, and a contact adhesive should be used.
#4 soopercooper
soopercooper
  • 110 posts
Posted 20 July 2005 - 04:30 PM
Thanks guys - something to look forward to then!
Not sure about removing everything from car though - I just slid the two roof frame halves off the cant rail, whithout removing anything - wasn't difficult? Is this perhaps different on a Mk2 to later models?
#5 Woody
Woody
    Ring Runner 2005
  • 1,763 posts
Posted 20 July 2005 - 04:31 PM
The best stuf to use on the edges is "refix" tape , basicly glue on a roll , it is repositional (is that a word?) NOT double sided tape or contact glue (this can stain)
it also helps if the headlining has been kept in the airing cupboard , when positioning the head lining it is best to have a small fan heater in the car to keep it all nice and warm .
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 July 2005 - 09:17 PM
ah does the MK2 still have the frames instead of the stretched lining ???
#7 soopercooper
soopercooper
  • 110 posts
Posted 20 July 2005 - 11:09 PM
Yep, has 2 frames - front and rear that just slide in and out of the rails.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 21 July 2005 - 07:01 AM
well in that case it's just a matter of attaching the newton lining to the frame.. which is no where near as difficult as the other lining.
#9 mini_sam
mini_sam
  • 1,381 posts
Posted 21 July 2005 - 10:24 AM
i saw roof lining fitting on "a car is born" where they made the three Mini's...it looked rather hard, took about 5 of them to fit it! :nugget: ... and they were proffessionals! :rolleyes: :P
#10 Purple Tom
Purple Tom
  • 4,921 posts
Posted 21 July 2005 - 12:35 PM
argghh!! I really am not relishing refitting the roof lining to the Clubby! in fact, b*gger it, i'm not going to bother! I'll just get some black carpet and stick that to the inside instead I reckon :tongue: (and it'll add to the headroom not having a headlining)
I hope you get it sorted ok soopercooper!
#11 binge
binge
  • 2,508 posts
Posted 17 March 2006 - 07:09 PM
ahh S**t, is it really that hard to fit! :D
Ive taken mine out already. Gona put a black one in.
Ive got nothing in my car at all though. Its a bare shell! :)
#12 kada1980
kada1980
  • 608 posts
Posted 17 March 2006 - 07:21 PM
I fitted the roof lining in the mini a couple of days ago took me the best part of an hour, no glue no mess used the half moon clips that you can get from minispares.
#13 mini-mad-dan
mini-mad-dan
  • 467 posts
Posted 17 March 2006 - 10:49 PM
a car is born- isnt' it called dream machines? or am i being dumb?
#14 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 17 March 2006 - 11:27 PM
You're supposed to use glue (or tape) and the clips together. It will start to shrink when it gets warm this summer and if you haven't glued it all the way along the edges it will shrink more between the clips and start to pull inwards. The door and opening rear window seals won't hold it as tight as the front and rear screen seals do.
Don't use a black one Binge, I did and I regret it. Makes the car feel quite imposing.
Mk2 roof lining is easy, wrap it round the frames as the original was and then stick them back in, I think the front one has to go in first. It's in my ancient Mk1/Mk2 manual, I'll look it up and get back to you.
#15 kada1980
kada1980
  • 608 posts
Posted 17 March 2006 - 11:53 PM
The clips have a barbed hook on them and i doubt that glue will be any better, but time will tell, its a used roof lining so i'm assuming any play has already been taken out by the previous application.
