Help Needed.
SolarB
, Nov 11 2008 08:27 AM
6 replies to this topic
Posted 11 November 2008 - 08:27 AM
I removed the engine steady bracket to repair a cracked crossmember but stupidly didn't measure the bracket's position.
Could some kind soul give me the dimension from the top of the cross member down to the bracket (see arrow in photo).
[attachment=74380:Drawing1_d.jpg]
Posted 11 November 2008 - 05:45 PM
Anybody this evening?
Posted 11 November 2008 - 11:41 PM
Small bump.
Posted 12 November 2008 - 12:13 AM
Haven't got one to measure but it will be the same as the assembled engine steady bar.
Posted 12 November 2008 - 08:18 AM
Yes, problem is I haven't got a steady bar with rubbers at the moment.Haven't got one to measure but it will be the same as the assembled engine steady bar.
Posted 12 November 2008 - 08:25 AM
here you are sir.. 28mm from the top of the croosmember tothe top of the bracket. Just in case it is 84mm from the right side of the left strengthener to the bracket. Hope that helps.
Jason
Jason
Posted 12 November 2008 - 11:06 AM
Jason, you're an absolute star, that's my evening sorted out.here you are sir.. 28mm from the top of the croosmember tothe top of the bracket. Just in case it is 84mm from the right side of the left strengthener to the bracket. Hope that helps.
Jason
Cheers,
Graham.
