Gear Linkage
6 replies to this topic
#1 mini_lad_deacon
mini_lad_deacon
  • 277 posts
  • Local Club: tynemouth
Posted 11 November 2008 - 05:01 PM
im finding it hard moving my gear stick left to right in nuetral and moving from 2nd to 3rd etc , its only just started doing this this week. what could be causing this?
#2 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 11 November 2008 - 08:54 PM
Primary gear, selector forks?
Have you checked the rod beneath the car where it enters the gearbox? Check the roll pin hasn't come adrift.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 14 November 2008 - 02:25 PM
This is a very common problem, the cause is the reverse idler bush which has started to walk out the side of the gear...
There is no solution, other than pulling then engine and removing the gear from the gearbox, and pressing the bush back in, or alternatively replacing the two bushes which are in the reverse idler with the better ( older ) single bush.
#4 icklemini
icklemini
  • 2,982 posts
Posted 14 November 2008 - 04:55 PM
disconnect the rods from the back of the gearbox and see if the problem goes away...
seen this a number of times being the gear-stick-box needing a clear out and a regrease...
#5 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 13 December 2008 - 07:47 PM
I've got the same problem.
First to second is fine.
Third to Fourth is fine.
Reverse is 'in there somewhere'.
But second to third? No chance - unless you're lucky.
The mini in question has been in storage for eight months.
Which of the possible solutions above should I investigate first?
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 14 December 2008 - 07:39 AM
do the ones which don't involve removing the engine first...
#7 daemonchild
daemonchild
  • 2,341 posts
Posted 17 December 2008 - 02:46 PM
The garage says it'll be the engine removal.
They quoted £1000 to sort the problem.
I think we'll be learning how to remove mini-engines then! :thumbsup:
