Edited by scoobyvan, 14 November 2008 - 12:03 AM.
No Reverse
Posted 14 November 2008 - 12:02 AM
Posted 14 November 2008 - 08:09 AM
If it has an exposed rod, then it's a rod change, if it has a long aluminium case from the box to the gearstick then it's a remote..
Once that is known then may have a better idea of the problem.
Posted 14 November 2008 - 11:43 AM
Is the gearstick going into location and just not finding reverse, or will it not go into location?
Guessworks - above - is our local gearbox whizz.
Dave
Posted 15 November 2008 - 05:06 AM
in neutral all the way to the right then lift the gearknob up, which should pull up the whole gearstick, and it should be able to go further right, then down.
Dave
Hello Dave, It won't go into the location. I can only shift the "H" pattern. When in neutral, I move stick all the way to the right and then down, it goes into 4th, I can't force it any further over to where I assume reverse would be. I also tried pulling up on stick and it doesn't budge at all. I'm going to remove the shift boot tomorrow and also jack it up and have a look around. I'm hoping it's something to do with the linkage. Do all the minis require lifting up on the stick to get it into reverse? thanks, Herb
Posted 15 November 2008 - 08:07 AM
No they don't hence my first question, is it a rod or remote change.
Posted 22 November 2008 - 11:00 PM
Dave it looks like the remote change type. It is an aluminum housing. I removed the shifter boot and the two screws that hold the shifter in, also removed the round rubber plug on the side. Can't see anything loose or wrong. The little plastic thing is intact on the end of the stick etc. I assume the problem resides in the gear box itself? herb
Posted 23 November 2008 - 07:57 AM
Remove this and then remove the spring and detent...
With that removed, can you select reverse ?
If you can then replace detent, spring and bolt/reverse switch, and try again.
Posted 23 November 2008 - 11:29 PM
It's probably the plunger which is stuck, if you look on the front of the box there is a big hex bolt ( or a reverse switch ).
Removed hex bolt located on the front of the gear box below oil filter, removed spring and detent. Still can't shift into reverse. Did I remove the correct detent? If so, now what? thank you for your help. herb w.
Posted 23 November 2008 - 11:36 PM
When it is in neutral, I simply hit/tap it with the palm of my hand into reverse. Only way it seems to want to go in.
Posted 23 November 2008 - 11:43 PM
Not sure if this is any help. I have a remote type gearbox, to get mine into reverse I don't lift it up or push it down.
I'm tempted to slip a pipe over the shift handle and force it all the way over to the right LOL!!! I've tried bumping it etc, and it simply won't go all the way over. I move it as far as it will go to the right and then move it down and it goes into 4th gear.
Posted 24 November 2008 - 08:26 AM
Unfortunately this is gearbox out to remedy...
There is an oil lubrication hole above the spring, near the input gear.. This may have been clogged with some debris which is preventing the spring from compressing. Only way I've freed this is with some air and a sharp tap on the other end of the selector rod.
Posted 24 November 2008 - 11:39 PM
If it's not that detent, then it's the other at the other end of the box...
When you refer to the selector rod, do you mean: shift rail? Which goes thru the shift fork? (different terminology). It almost feels like a "interlock" problem. (prevents shifting into two gears at the same time). When you refer to debris, would that be metal shavings etc from the engine? I haven't changed the oil yet. (Won't if buddy wants to sell the car), but I did loosen the drain plug and the "oil" is like sludge, very thing and nasty looking. Do you thing an oil change would help free up stuck spring you mentioned? There is nothing else I can do short of pulling motor? thanks again, herb w. : )
Posted 25 November 2008 - 08:00 AM
Posted 25 November 2008 - 01:01 PM
If the oil's as bad as you say, then i'd be tempted to pull the engine anyway....
We are really just trying to get the car drivable to sell.
Posted 25 November 2008 - 01:26 PM
