Metro 1275 Automatic Engine - Easy To Convert To Manual?
8 replies to this topic
#1 burnerking
burnerking
  • 173 posts
Posted 16 November 2008 - 10:38 PM
I'm after a metro 1275 engine to put in my mini and seen a few that are automatic. I want my mini to stay manual - is it as easy as just buying the metro 1275 engine with an auto gearbox and simply replacing the auto gearbox with a manual gearbox?
That seems too straight forward, is it?
Edited by burnerking, 16 November 2008 - 10:52 PM.
#2 Flippy
Flippy
  • 293 posts
Posted 16 November 2008 - 11:21 PM
a good mate of mine did this little while back, i dont think he had any issues other than not having a dip stick...
#3 Ethel
  • 25,938 posts
Posted 16 November 2008 - 11:25 PM
Alas no, the oilways in the block are different so it would require some machining to convert.
#4 mk1leg
mk1leg
  • 9,343 posts
Posted 16 November 2008 - 11:26 PM
Hi..you will need to replace crankshaft as the auto's differ from a non auto + you will need std clutch housing ect...... :dontgetit:
#5 miniobsessed
miniobsessed
  • 211 posts
Posted 16 November 2008 - 11:37 PM
It's a fairly straight forward job to convert most A and A+ auto's to manual (all except the very late type A+). You could do it yourself or easily employ a machine shop to make the modifications for you.
All is detailed in this thread from my favourite hang-out ausmini.com :dontgetit:
http://www.ausmini.c...opic.php?t=1461
#6 Mart8V
Mart8V
  • 505 posts
Posted 17 November 2008 - 12:19 AM
By the time you have paid for machining work would you not just be better off to buy a manual engine? Plenty of bored out units etc on here from time to time! That way you get manual and fun.... :dontgetit:
#7 burnerking
burnerking
  • 173 posts
Posted 17 November 2008 - 10:18 AM
cheers for the info- not such a straight forward jobby then. I'll just go for a manual, easier option
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 November 2008 - 10:52 AM
Hi..you will need to replace crankshaft as the auto's differ from a non auto + you will need std clutch housing ect...... :D
And this is completely untrue.... Auto crankshafts are exactly the same as manual....
#9 John H
John H
  • 768 posts
Posted 17 November 2008 - 12:57 PM
correct just the torque converter on the end. which prob means the auto crank would be less stressed.
