any help greatly appreciated
Posted 17 November 2008 - 05:34 PM
Posted 17 November 2008 - 05:51 PM
Posted 17 November 2008 - 05:55 PM
Posted 17 November 2008 - 06:02 PM
have you had the camber, castor and tracking set up with your existing set up ?
The solution is either to measure the camber you have and then get bottom arms that correct this to where it should be, or get adjustable bottom arms.
Posted 17 November 2008 - 06:18 PM
Posted 17 November 2008 - 06:45 PM
Posted 17 November 2008 - 07:13 PM
Posted 17 November 2008 - 07:24 PM
If the car is that low, is it not sat on the bump stops? If so this is a very dangerous way to set the suspension and could result in poor handling when you least need it or expect it.
Posted 17 November 2008 - 07:38 PM
Posted 17 November 2008 - 10:35 PM
Book me inQUOTE (Bungle @ Nov 17 2008, 05:51 PM)
no, what would be my best option for doing that? (Is it difficult to do?)
QUOTE (GraemeC @ Nov 17 2008, 05:55 PM)
Would the adjustable arms correct the angle? The only ones I've seen say negative camber adjustable arms, but I need some to make it more positive; or is that just a name and can still be adjusted for more positive?
A bent tie rod - would shorten its length.. shorter increases castor and adds + camber...but something like bent tie rods would effect camber, tracking and caster
