Jap Imports
8 replies to this topic
#1 Mini Minty
Mini Minty
    Just On Tickover
  • 7 posts
Posted 18 November 2008 - 12:30 PM
Hi
I have recently bought a 35th Anniversary edition Mini Cooper (Minty). He is a Japanese Import and is in mint condition.
I am looking to do a few modifications to him and I want to start with the exhaust.
I had a look under Minty on Sunday and between the cat and the first rear silencer there seems to be some sort of sensor. I believe this connects to the ECU (but not hundred percent sure)
I want to put a RC40 Millennium Stainless exhaust on him, but I am not to sure what to do about this sensor.
Can i just take it off or does it have to be there for Minty to run?
Hope someone can help me!
Dave
#2 beaubrad
beaubrad
  • 736 posts
Posted 18 November 2008 - 12:35 PM
keep it if your going to keep her original ,wont be hard to weld the nut in the new exhaust brad
#3 rozzer1275
rozzer1275
  • 439 posts
  • Local Club: ah
Posted 18 November 2008 - 12:37 PM
a lot of jap imports skylines and such have a EGT sendor next to the cat, usally the wire is braided, also some eary cat cars had the lambda probe quite far down the exhaust.
#4 Mini Minty
Mini Minty
    Just On Tickover
  • 7 posts
Posted 18 November 2008 - 02:06 PM
So am I going to need to keep the sensor there when I come to replace the exhaust?
Sorry my first mini I dont really know very much bout them!!
#5 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 18 November 2008 - 02:42 PM
Do you happen to have the red, round "EXH" warning in the lower right dash rail (usually next to the Rear Fog light switch) and/or the car make a "beep" sound for 1-2 seconds when you turn the ignition on? On Japanese cars there's a sensor to measure exhaust gasses from after the cat to a little box on the crossmember under the driver's seat to tell you when the exhaust gasses are waay above permitted limit.
When the ignition were turned on, the sensor perform a check-up, that's why the lights go on for a few seconds (1-3 sec) and a beep was heard. When it does this while you're driving, then your emissions are way out... I don't think they were connected to the ECU, though....
#6 PMM
PMM
  • 78 posts
Posted 18 November 2008 - 03:14 PM
thought it was a lambda sensor......
I have a Jap Mini also with Cat I always took it as bring the a lambda sensor
I got myself this for mini via Ebay the bloke trades on there... http://www.minitrail...com/exhaust.htm
Has the the sensor hole and keeps the Jap theme :D
Edited by PMM, 18 November 2008 - 03:14 PM.
#7 Mini Minty
Mini Minty
    Just On Tickover
  • 7 posts
Posted 18 November 2008 - 03:18 PM
Yeah it does that beeping thing when i first put the key in!
#8 Mini Minty
Mini Minty
    Just On Tickover
  • 7 posts
Posted 18 November 2008 - 03:22 PM
Thats is a very good website thank you.
What sort of exhaust do you have or your import?
Does it sound good?
#9 PMM
PMM
  • 78 posts
Posted 18 November 2008 - 03:40 PM
The link Is the exhaust I have fitted.
Pricey though about £170 .
This is it fitted to mine... >> Clickky <<
Sound great in a Loud deep rumbling way... does come with a reducer that makes it less noisy.
