My Mini Is In Despreate Need Of Resealing!
6 replies to this topic
#1 soph83
soph83
  • 13 posts
Posted 19 November 2008 - 09:11 AM
hey I know im not apart of the mini group yet been busy as just moved here
but i was wondering if i could get some advice my mini is in despreate need of the back window to be resealed I have got the seals but not the tools or anything to do, does anyone know how much it might cost to get just the back window done????
thanx
sophie
#2 JohnGordon
JohnGordon
  • 966 posts
  • Local Club: N.W Mini's / O.D.M.C
Posted 19 November 2008 - 10:41 AM
It should only take a garage about an hours labour to do it, or buy the filler tool from mini spares (under £5 i think) and a bit of string an you can do it easily yourself.
#3 soph83
soph83
  • 13 posts
Posted 19 November 2008 - 11:02 AM
oh cool that sounds good, im not sure i would trust myself with getting the window out but woulc be worth a go
thank you
#4 Ethel
  • 26,187 posts
Posted 19 November 2008 - 11:28 AM
If you mean the the back rear and not side rear glass it is easy enough to tackle yourself. Allow yourself a full day as you may find a spot of rust is the reason for the leaking. Remove the chrome filler strip and push the glass from the inside in one of the top corners - a friend to catch it if it pops out would be handy. Refitting is the reverse, you'll need something to lever the rubber and filler strip with - teaspoon handles work well as does washing up liquid as lube. Do your best to push the filler strip as you fit it - you nearly always end up with a lil bit left over at the end :thumbsup:
#5 soph83
soph83
  • 13 posts
Posted 19 November 2008 - 11:39 AM
ok cool i think i might try do it myself save me some money as ill have to get the back side ones done too which will be easy enough to do, i only noticed this morning that there is a gap in the seal at the bottom near the heather so i think thats the problem, so need to get it done asap as in this weather my back seats get soaked from the amount of damp in the back
thank you lots for your advice
#6 Ethel
  • 26,187 posts
Posted 19 November 2008 - 11:52 AM
lift out the seat base
Peel out 6 inches of the filler strip 'n have a go at refitting it - will give you an idea of what's involved.
#7 JohnGordon
JohnGordon
  • 966 posts
Posted 19 November 2008 - 11:54 AM
There's also a a step by step guide on here somewhere, I'll have a lookie for it
