Cooper S Engines - Differences And Identification
4 replies to this topic
#1 Ace of Clubs
Ace of Clubs
  • 91 posts
Posted 23 November 2008 - 06:29 PM
Would anyone like to recommend either a good book or website for identifying cooper s engines and their internals.
Or anyone on here fancy having a bash ??
I know there are the three variants 970, 1071 and 1275 but what are the differences between them?
How many of the same parts were used inside each one.
I guess the only really vital parts of concern are the block, crank, conrods and pistons.
Any help appreciated.
#2 BLUE ITALIAN JOB
BLUE ITALIAN JOB
  • 204 posts
  • Local Club: thames valley
Posted 23 November 2008 - 08:14 PM
check out the vizard bible on mini's - how to modify your mini , it gives a good quick guide on what the differences are and i think it may even go into casting No's
#3 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 23 November 2008 - 10:54 PM
This book is also pretty good too: -
http://www.amazon.co...p...0824&sr=1-1
#4 62S
62S
  • 1,244 posts
  • Local Club: You must be joking!
Posted 26 November 2008 - 09:54 PM
970 & 1071 used the same block.
1071 & 1275 used same rods and pistons.
All use different crankshaft.
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 26 November 2008 - 10:24 PM
Cooper S block are very distinguishable from other big bore blocks...
1. They actually look like small bores with only 1 core plug at the number 4 piston end and have tappet chests
2. The don't have the fuel pump hole drilled in the back of the block
3. the usually have a big tang on the back saying 970, 1070 or 1275 ( but early GT blocks also have 1275 on the back too )
The head will either be an AEG casting, or a 12G940, but will have the AEG part number stamped into it.
Edited by GuessWorks.co.uk, 26 November 2008 - 10:25 PM.
