Non Mini - Engine Wont Run On A 1.2 8v Punto
Posted 24 November 2008 - 01:29 PM
The car is a 1.2 8valve MK1 Fiat punto.
Well last week i changed the headgasket on my punto,, chaning the:
Head gasket
Cam belt
Cam belt tensioner
HT leads
Spark plugs
Coil pack
All filets
Oil
I then fired the car up and it was all running fine, then drove it a 10+ miles into town everything seemed fine, maby a little slighish.
I then went to town for about 4 hours and went to drive home, so i fired the car up, it all seemed normal, drove about 100meters down the road and the car just died.
When timing the engien up i turned it over about 5 times checking the timing markes every time and it all lined up, also there is clearance between the valves and the pistons when at TDC, so even if the timing was out it wouldnt bend a valve.
So now when i go to start the car if i have my foot flat on the floor and after about 20 seconds of turning it over it will splutter and just about idle, then after keeping my foot on the floor for about another 30 seconds it starts to pick up and rev, so it seems like at first is only firing on 2 or 3 cylinder then starts to fire in more after time.
Although it seems like its fore that an electrical firing problem, i stuck the old plugs, leads and coil pack back on and it still had the same problem.
So does anyone have any idea atall what could be the problem as i really dont have a clue what could be up with it nore did the recovery guy, that had been working in garages and then for the recovery company for 33 years.
So if you have the slightest idea of what could be up please say.
Posted 24 November 2008 - 07:06 PM
Off the top of my head, possibly an ECU or sensor fault?
Hope that helps, good luck!
Cheers, Neil
Posted 24 November 2008 - 07:43 PM
Ill get a compression test done and see if that shows anything up, but i really dont have a clue what could be up, becuase i have checked the timing loads of times, changed back to the old ignition stuff and it still doesnt work
Posted 24 November 2008 - 07:51 PM
Posted 24 November 2008 - 07:54 PM
But a compression test will confirm this...
Posted 24 November 2008 - 08:01 PM
Would be worth checking that as a fault there can cause the sort of problems you describe. It could well just be loose so have a good look at it.
Tom
Posted 24 November 2008 - 08:14 PM
I guess i could order a new one a try that.
Posted 24 November 2008 - 08:18 PM
Posted 24 November 2008 - 08:21 PM
Could the crank sensor mess up the spark?
Posted 24 November 2008 - 08:25 PM
I had the same trouble with the crank sensor on the Mini not long ago.
Posted 24 November 2008 - 08:50 PM
Posted 24 November 2008 - 10:08 PM
what syptoms did you have to do headgasket???
Posted 26 November 2008 - 05:37 PM
I got the rocker cover off and found that it was being starved of oil and this had caused two of the cam followers to sieze, so i got the head off and found that i had very studidly had put the headgasket on upside down, thus blocking the oil vay to the head
So i tapped the valves back in the had the cam followers stuck and this knocked the followers out and the seemed to fit nicely and move freely, and the had very little wear on them, so the plan is to get the valves out the head, and see if i can lap the cam followers in and see if that will make the fit smoothly, if that faild then ill have to search for a new head. But the damage really isnt very much atall as i hadnt traveled very far with the problem.
Well i get to take the valves out, but my valve spring compressor wont fit the head as the valves springs are set into the head
Once they are out ill lap everything together and see if im going to be able to use it again.
Luckly there was no damage to the pistong or bore, so once iv sorted the head it'll be fixed and i can get on with working on my minus
