Mirage Manifold T2 Turbo
11 replies to this topic
#1 mini_yom
mini_yom
  • 23 posts
Posted 29 November 2008 - 08:51 PM
hi
i found some infomation on the mirage manifold t2 turbo conversion
and am looking to put it on my mini. just wondering if any one had
done it to a 998cc mini before, if so, was it fairly straight forward
or any problems, and also how much it cost all in all.
cheers
Jay
#2 Jack Jones
Jack Jones
  • 617 posts
Posted 29 November 2008 - 09:07 PM
hi
cheers
Jay
compression ratio will need lowered for starters if you want o run a little boost unless its a a seires they have 8.5:1 ratio in standard form get some good boost going through that
#3 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 29 November 2008 - 09:26 PM
hit the search button, wil_h has posted the link to his 998 turbo build using the mirage manifolds loads of times.
#4 mini_yom
mini_yom
  • 23 posts
Posted 29 November 2008 - 09:29 PM
so are you saying if its an A series engine i dont need to lower the compression ratio.
(sorry if im being thick im very tired!!)
yea i believe i have an A series engine. its a 1983 mayfair
i found this list from turbominis.com
1x Manifold kit, including down pipe
1x Turbo of the T2 variety
1x Inlet manifold (can be of the MG Metro style)
1x Actuator
1x Oil Feed
1x Turbo Manifold Gasket
At least 2x 5/16th K-Nuts
4 Large washers with a 5/16? hole
5x mate K-Nuts
2x 14mm Banjos
2x Banjo Bolts to fit thread of water cooling points on turbo
1 length of 13mm steal pipe
2 lengths of heater water pipe hose
Length of vacuum pipe (4mm)
An adjustable top engine steady, or modify your own
1x 2? Exhaust clamp (preferably a 1 bolt fixing)
13mm 90�� Pipe capable of withstanding oil
2x Stainless hose clips to fit 13mm pipe
is this a whole list or is there more to buy?
thanks again
#5 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 29 November 2008 - 09:36 PM
yeah there's still all the other bits involved in a turbo conversion, fuel pumps etc.
plus with a mirage setup you have to make your own oil drain up, make an actuator bracket, make a bracket that holds the downpipe off the pot joint, cut the wastegate tab on the turbo and reweld it other side.
#6 Jack Jones
Jack Jones
  • 617 posts
Posted 29 November 2008 - 09:37 PM
in a 83 i would have thought it wouldve been a+ engine, on either engine if you could find a 12g295 head would be best option believe they have got slightly opened out ports and bigger valve then a 83 998
depends on boost and intercooler size to c/r
#7 mini_yom
mini_yom
  • 23 posts
Posted 29 November 2008 - 09:40 PM
my god this sounds complicated
#8 mini_yom
mini_yom
  • 23 posts
Posted 29 November 2008 - 09:43 PM
[quote name='just_jack' date='Nov 29 2008, 09:37 PM' post='1238015']
really ive been under the assumption that ive got an A seris
engine for 2years
#9 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 29 November 2008 - 09:53 PM
If it's the original engine as fitted from the factory, it will be the later A+ type engine.
#10 Jack Jones
Jack Jones
  • 617 posts
i see turbo phil is looking get him to reply he knows his stuff
dont hold me to that either,
all i know is i had an a+ in my '82 but it had an engine change before i got it and i dont know what year that engine was but that was deffo a+
#11 mini_yom
mini_yom
  • 23 posts
Posted 30 November 2008 - 12:40 AM
hi turbo phil, apparently your the guy to talk to!
im interested in doing this conversion could you recomend any other parts to replace
like pistons crank ect, because i dont want to do this and have my engine blow up or
something!
also do you have a rough price guide to go on and where you would source the parts?
cheers mate
#12 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 30 November 2008 - 08:19 PM
www.turbo-mini.com
Check Phils site out it goes through all the parts that you will need to look at and recommendations of mods to each
Also get yourself over to
http://www.turbomini...orums/index.php
There is a wealth of information there but dont just post do some searching first and then if you still cant find an answer then post! :thumbsup:
