re fitting a new water pump
7 replies to this topic
#1 PLIMERICK
PLIMERICK
  • 72 posts
Posted 26 July 2005 - 07:57 AM
hi ive just removed a cracked water pump
and am about to fit a new one
is there anything tricky of things i should watch out for whilst doing this
tks
#2 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 26 July 2005 - 08:28 AM
not really, just make sure the surfaces are clear so that the gasket has a good seal!
#3 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 26 July 2005 - 09:17 AM
another thing to insure is that the clips for the bypass hose are secure after you have fitted the water pump and before refitting the radiator..
#4 mattvallins
mattvallins
  • 1,139 posts
Posted 26 July 2005 - 09:45 AM
And make sure the bypass hose is THERE before you bolt it on :fear:
May as well replace it while you are there, there are about a quid and some motor factors stock them.
#5 PLIMERICK
PLIMERICK
  • 72 posts
Posted 26 July 2005 - 09:46 AM
GOT a new bypass hose and radiator hose while i was at it
#6 Purple Tom
Purple Tom
  • 4,921 posts
Posted 26 July 2005 - 09:58 AM
try to use heater pipe rather than the pants convuluted type bypass hose. Heater pipe is much more durable. Minispares also do a Kevlar bypass hose, I fitted one to a performance 998 a while ago, there's been no problems yet.
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 July 2005 - 10:09 AM
Depending on how old and how well put together your engine is, you may find some dowels lining the waterpump up. If you do then swap them into the new pump body, if not then just take more care to align it to the gasket.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 26 July 2005 - 10:18 AM
yes, as mini84 says use a section of strong heater pipe instead of those stoopid consetina(?) type hoses for the bypass.
