Steering rack change
Posted 26 July 2005 - 09:00 AM
also having had a look at the old steering rack now there doesn't seem to be anything loose when turning it by hand as you'd expect there to be if it was a fault? anything else that could cause this steering effect, its not bearings or ball joints or anything like that either. steering column? possible?
If not I suppose i'll find out when I can get the new rack in.
just any info from anyone whos done a steering rack would be great. even just a basic list of things to do?
the car is a multipoint injection P-reg cooper.
cheers for anything you guys have to offer.
Posted 26 July 2005 - 10:22 AM
Posted 26 July 2005 - 10:32 AM
Posted 26 July 2005 - 10:42 AM
Posted 26 July 2005 - 03:57 PM
as for the packing strips, I hadn't realised they were so important, will make sure they are back on when I put it back together. so they go inbetween the column and the bolts?
don't think the ubolts were loose when I took it out, it would explain the looseness, although I have a feeling that the steering vanished as the wheels passed straight, which doesn't really make much sense.
as for getting the new rack in, i've been pushing it in from the side but the U-bolt by the column really does have a snug fit, combined with stopping it from getting forced around the rack and moving etc, whilst slotting the pinion in its a bit of a nightmare, I think its just a case of a lot of patients, time and getting very lucky. could do with more clearance from the subframe though, forwards not down. just don't think thats possible.
cheers for the ideas guys.
Posted 26 July 2005 - 04:19 PM
Posted 27 July 2005 - 09:16 AM
and after all this it'll probably just turn out to be a lose bolt or steering column teeth. :nugget:
Posted 28 July 2005 - 09:11 AM
this job just gets better and better.
Posted 28 July 2005 - 09:27 AM
Posted 28 July 2005 - 09:40 AM
Posted 28 July 2005 - 11:57 AM
don't suppose anyone in sussex wants to come round and finish the job for me as i'm just about fed up with it. :grin:
Posted 29 July 2005 - 12:43 PM
Posted 29 July 2005 - 01:02 PM
Posted 01 August 2005 - 10:22 AM
and adam it is in the haynes section 10 number 26 or around there under rack and pinion.
basically depending on the year of the car undo the subframe mount tower bolts, on a 96 they are 1" 5/16 hex bolt at some point they changed to this from 2 smaller bolts, these are located at the rear corners under the bonnet, then take the wheels off (you will need the car jacked up from anywhere but the front subframe) undo the track rod ends from the rack and the top suspension strut bolt, take off the steering column by undoing the bolt holding it to the dash and the bolt holding it to the pinion right down the bottom, undo the U-bolts under the carpet. in the engine bay with the engine supported on a jack undo the engine stabiliser bar (just for good measure) and then under the car undo the rear subframe bolts 2 bolts either side, and loosen the front bolts that go through the front of the car by the tie rods. lower the subframe/engine down, haynes stated 76mm but I could only get around 40mm, then reach in and remove the Ubolts from either and pull the steering rack out. As in haynes refitting is a reversal of removal, maybe not quite as easy but...
make sure you either put the track rod ends back with exactly the same number of turns or get the tracking done straight away! if you want to change the track rod ends they are pretty obvious how to do with a bit of brute force or a ball joint seperator, and only around a fiver each so probably worth it whilst your there.
probably full of errors and mistakes but this is how I got it done.
Posted 01 August 2005 - 12:21 PM
Cool, thanks Gibbo. Somehow i think i'm gonna screw it up but got nothing better to do :grin:and adam it is in the haynes section 10 number 26 or around there under rack and pinion.
Also in case you were wondering it's an 1982 mini
Thanks again
