Wheel Alignment
Posted 04 December 2008 - 04:44 PM
Thanks in advance Pete
Posted 04 December 2008 - 04:47 PM
Posted 04 December 2008 - 04:58 PM
Silly question and please dont take the p**s but which ones are theyHave you checked the tie-bars because if their bent, this can cause wheel geometry problems?
Pete
Posted 04 December 2008 - 05:13 PM
As standard parts they were designed for the Mini 850 with 10" wheels, so it's quite common for them to bend what with the extra pressure of larger wheels and bigger engines. The most common problem is that the average tyre fitter bends them when jacking up the front of the car.
Heavy duty replacements make a big difference.
Posted 04 December 2008 - 10:22 PM
this is true on most cars not just minis.
if you have a spirit level - measure the bubble on both sides to initially check its about the same... ideally, get the geometry checked.
Posted 05 December 2008 - 12:42 AM
I used to work at a tyre place (Just Tyres) but out alignment kit was rubbish and old! I used to send our customers to the better places to get it checked on proper equipment! I didn't like working there, so I wasn't fussed.
You could always jack the front of the car up, and compare each side to see if you can spot a difference?
Posted 22 December 2008 - 10:22 PM
Had the tracking checked and adjusted but the wheel does seem to be still set under the arch more on the passenger side the guy at the tyre centre said the sub frame could be fitted wrong is this possible also he said its possible to shim/pack the hub out to suit the other side is this corrrect another suggestion was to use a 5mm spacer on the wheel
any suggestions please
Pete
Posted 23 December 2008 - 10:30 PM
AnyoneRight im back AGAIN
Pete
Posted 24 December 2008 - 12:29 AM
If it is camber it could be bushes/swivel pins etc. Jack it up and see if anything feels loose while you wobble the wheel.
If it is the whole wheel then maybe the subframe is over to one side, check the mounts and wiggle the steering wheel side to side while you look to see if the top big nuts on the subframe move about.
Has the car had new wings/front/a panels, if so could the wing just be distorted which is causing the problem.
Posted 24 December 2008 - 12:39 PM
Posted 24 December 2008 - 01:19 PM
I have jacked it up and nothing feels loose and theres no play any were it has only just (20 miles ago) passed its mot with flying colours. It is the whole wheel yes and its also had new wings and a panels by the look of it if the sub frame is to one side is it possible just to loosen things and push it over or is that just me being stupidIs it the whole wheel that is set in by 5mm or is it just the top of the wheel (ie too much camber)?
Pete
Posted 24 December 2008 - 01:21 PM
The cones havent been replaced as far as i know but if they had collapsed woudnt that have been picked up on the mot 20 miles agoMight the rubber cones have collapsed? You did not say if you had replaced them when you rebuilt it. My Racing Green shows very similar symptoms and I am planning to replace the cones.
Pete.
Edited by secondopsman, 28 December 2008 - 11:02 PM.
