Ignition Light
Posted 05 December 2008 - 12:39 PM
I have had a problem with my ignition light not working.
While driving to the MOT sation today it came on and stayed on, only going off when the ignition was turned off.
Is this normal or what can i do to sort the problem??
Jon
Posted 05 December 2008 - 12:44 PM
Ignition light should only come on when ignition is turned on, once engine is running it should go off.
If its staying on its either
Wiring fault
slack or snapped fanbelt (snapped would also cause over heating though)
problem with the alternator.
Posted 05 December 2008 - 12:47 PM
Posted 05 December 2008 - 03:37 PM
The ignition light should always come on when the engine isn't running. If it comes on when it is it means the battery voltage is higher than the alternator's. Check your fan belt tension first.
it does not mean the batt voltage is higher that the alt it means the alt is not charging the batt. so the alt has stopped working or broken fan belt or wiring fault.
but it's prob the alt.
Posted 05 December 2008 - 04:26 PM
Also the light only comes on when the engine starts up and is running, it doesnt come on at all when just the ignition is on, what could this be? Are there any checks thats i can perform???
Jon
Posted 05 December 2008 - 05:21 PM
is it red or orangey/yellow?
Posted 05 December 2008 - 06:07 PM
Its definatly the ignition light, its red, does anyone know what i can do to check how to sort it, its just concerning me a little as its not working correctly, i dont really want anything breaking.
Jon
Posted 05 December 2008 - 08:02 PM
Posted 05 December 2008 - 08:17 PM
No, Ethel is right. If the lamp is on the battery voltage is highter than the alternator output voltage. That can happen for a few reasons. The alternator can be working perfectly, producing the correct voltage at its maximum output and still not charge the battery. Without an ammeter you can't tell whether the battery is charging or not.
Posted 05 December 2008 - 08:33 PM
I have a multimeter but not sure how to test it.
What do i need to do??
Jon
Posted 05 December 2008 - 09:00 PM
so ive been a auto electrician (also sell alt as well) for the last 9 years. the alt will turn off the light when the output is correct. it cannot read the batt voltage.it does not mean the batt voltage is higher that the alt it means the alt is not charging the batt.
if it does not charge the batt and the correct voltage is coming out of the alt then there is a wiring fault between the alt and the batt.
jonb-5
get the multimeter and put it to volts and connect the red leed to the big red lead on the alt and one to the body of the alt with then engine off and see if there is a 12v feed if so start the engine up and put the leed on the red wire again and see what the reeding is should be over 12.9-13.9 if its till 12v then the alt has had it.
then check the same on the batt.
the thing is if the light comes on when the engine is running then it is the alt as the light goes out to complete the circuit from the alt but if it stays on then the circuit is not complete inside the alt.
Regardless of battery voltage (unless its totally flat) the ignition light should come on when the ignition is turned on...yours isn't
The fact it comes on when you start the engine proves bulb is fine so really points to dodgy alternator..
Not sure how much to have one tested but I suspect probably more cost effective to get a new one.
Posted 05 December 2008 - 09:53 PM
So even though the circuit from the warning lamp is still connected to the rotor and is live, the alternators already putting power into the winding at the same value, the only way the bulb can come back on is if there is less power going into the rotor directly from the alternator than is available in from the battery.
For example if the battery was at 12V and the alternator was at 8V then 4V would flow through the warning lamp circuit causing it to glow slightly.
Glowing Ignition lamps on high load can also be due to bad earth on istrument pack circuits, and Lighting circuit.
Check voltage at battery:
battery voltage settled is 12.6 to 12.8 volts for a very good battery, 12.4 to 12.6 for an average battery.
Start car and voltage should rise from upto 14.4v (OK)
Check output of alternator (voltmeter from large terminal to earth) - 14.4v dropping to 14v on load
- earth points to check: alternator body, engine, body (voltage to be the same)
Posted 06 December 2008 - 12:41 PM
This morning I have tested battery with engine on and off, the same reading for both 12.5 ish volts.
Also tested the alternator with engine on and off, this was also the same around 12.5 ish volts, roase a little when i put the revs up.
I thought the alternator was knackered so i took it out and took it to a local car place who tested it for me, under a load of 20amps.
They said it worked fine, my problem being a dodgy fues or connection and if i couldnt fine it to bring it down to them??
What do you reacon, as i have proved the alternator works ok.
Where should i be checking for wire route etc??
Thanks for all of the help
Jon
Posted 06 December 2008 - 12:57 PM
Make sure earth straps are tight and in good condition..
With nothing switch on you want close to 14volts at the battery with the engine running.
