I hope somebody can help me.
I have a 1988 Mini Mayfair and unfortunatly she broke down yesterday
After a long wait after she broke down I had the car inspected by the RAC man who kindly had a look for the problem of the breakdown. He suggested that it was fuel starvation fault and maybe the fuel filter or the carb is to blame. He suggested to strip and rebuild the carb and change the fuel filter.
This is how the car broke down:
The car started as normal in the morning with no faults, I drove it around about 1mile up the road and the engine seemed to be slowing down when I was accelarating.
I pulled over and inspected if the exhaust had come off because the straight through pipe was abit short and dosent really fit perfect so I was woundering if it had come out. I suspected this because the car was really loud wen I revved the engine.
The exhaust was fine and in place so then I checked the:
- engine temp (that was fine)
- fuel level (that was full)
- checked under the bonnet for a loose HT lead becuase the car drove like it was running 3 of the 4 cylinders but all of them was fine.
I then got back in the car (at this point it was still ticking over, quite unnormal I might add) and tried to pull away and the car wouldnt go. The clutch was fine it was just that it didnt seem to accelarate so i tried again and it died. I tried to fire it back up but I had no luck.
The started motor was turning but it seemed like there was no fuel.
Can anyone suggest any ideas?
The following has been done to try n get it started:
- Changed all the spark plugs
- Tested the ht leads and are all fine
- Opened the fuel cap to make sure that there wasnt any air trapped in case that could have been making a vaccum
Many Thanks
Gav
