What Is A Choke Tube?
Posted 07 December 2008 - 04:01 PM
Posted 07 December 2008 - 04:19 PM
Posted 07 December 2008 - 04:30 PM
Maybe he means the jet bearing if it's a HS? Might just need a strip and clean, though it wouldn't effect the mixture intermittently, it'd just hold the choke on.
Super sexy new feature on Burlen site
Posted 07 December 2008 - 04:34 PM
Overfueling for HS carbs:
- worn jet (oval were the needle goes in - look REAL close!)
- worn/stuck needle valve (needs to be 100% clean and spotless)
- sticking jet (if choke applied it goes down but not back)
- wrong setup
Overfueling for HIF carbs:
- worn choke mechanism seal (one or two o-rings)
- sticking choke lever
I could imagine - if yours is a HIF type carb - one would call the choke-mechanismn a 'choke-tube'.
To determine which carb you have:
This is the HIF type:
[Internal float chamber]
This is the HS type:
[external float chamber]
To check the jet it is advisable to use a magnifying glas to look at.
If you have a HS carb, look at the carb and a mate pulls the choke,
you'll see how the jet moves down. it needs to return fully if the choke is pushed back in.
If it doesn't - put a bit(!) of oil on and consider buying a new jet & bearing in the near future.
Spluttering on acceleration could be a matter of underfueling as well... Do you have enough oil in the dashpot damper?
Unscrew the black plastic screw on top of the carb and look if there's oil inside.
If not, fill the inner tube up with some fresh engine oil.
Hope that helps.
Cheers,
Jan
Edited by Asphalt, 07 December 2008 - 04:35 PM.
Posted 07 December 2008 - 11:25 PM
Posted 08 December 2008 - 12:58 AM
Hope that helps.
Cheers,
Jan
Do you mean standard 20W50 tesco value engine oil? I thought it was meant to be special stuff for the dashpot. If so that seems the simplest option to begin with. Thanks for all the advice
Posted 08 December 2008 - 02:29 PM
Hope that helps.
Cheers,
Jan
No you want a thinner oil for the dashpot, so 10W/40 would do, or the specific carb oil that Burlen sells.
