Battery Earth Cable
5 replies to this topic
#1 minibarmy
minibarmy
  • 493 posts
Posted 07 December 2008 - 04:14 PM
Anyone know a reason why my battery earth cable is so hot you can't touch it without it burning you?
It's a braided cable without any covering & 8" long going from the battery -ve to the boot earthing point.
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 07 December 2008 - 04:16 PM
it's drawing to much current
has it got a bad connection ?
#3 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 07 December 2008 - 06:31 PM
check the battery lead, esp. around the front subframe
#4 billyboy83
billyboy83
  • 262 posts
  • Local Club: www.16vminiclub.com
Posted 07 December 2008 - 07:08 PM
also are you running any amps and bits like that ?
#5 BLUE ITALIAN JOB
BLUE ITALIAN JOB
  • 204 posts
  • Local Club: thames valley
Posted 07 December 2008 - 07:47 PM
is the cable hot all the time or just after starting the engine ???
when engine is running does the alternator also get hot ??
#6 SolarB
SolarB
  • 1,397 posts
As long as it's the correct size cable, drawing extra power isn't you problem. You have a high resistance (bad) connection which is generating heat at the joint and travelling down the braid. Check and clean the connections.
