Rear Brake Cylinder Clips - Which Way?
8 replies to this topic
#1 dyanetski
dyanetski
  • 65 posts
Posted 07 December 2008 - 06:17 PM
just a quick one, when fitting the e clips on the back of the rear brake cylinders, which way round do they do go? as they are concave.
#2 icklemini
icklemini
  • 2,982 posts
Posted 07 December 2008 - 06:37 PM
Fit them so it holds the cylinder to the back plate:
so: <cylinder><backplate><clip this way around: ) >
this then holds the cylider tight against the backplate.
#3 dyanetski
dyanetski
  • 65 posts
Posted 07 December 2008 - 06:39 PM
i know that mate! but the clip is concave so can go on 2 ways around, not sure whick way it should go!
#4 james753
james753
  • 219 posts
Posted 07 December 2008 - 06:48 PM
Hello,
on mine, i put the clips with the middle of the 'cave' pushing against the backplate, with the two 'ends' of the clip on the cylinder side if that makes sense?
i would get you a photograph but am living in birmingham during term time, nowhere near my mini :thumbsup: (tho still only 20 mins away from minispares!... >_< )
tara
James
#5 icklemini
icklemini
  • 2,982 posts
Posted 07 December 2008 - 07:13 PM
so the (bad) explanation wasnt understandable?
cylinder - backplate - clip ')' way around.
or another way is have the clip ( way around - backplate - cylinder
so that the middle of the clip is away from the backplate..
Edited by icklemini, 07 December 2008 - 07:16 PM.
#6 zodiac123
zodiac123
  • 64 posts
  • Local Club: Local Classic car club
Posted 07 December 2008 - 09:11 PM
Those E clips are swines. I was almost in tears after half an hour of battling with one.
In the end I bought a box of circlips and fitted one of those instead. At least then I could us my circlip pliers and and fitted it in about 3 seconds.
#7 Ethel
  • 26,082 posts
Posted 07 December 2008 - 09:50 PM
If you think of the clip as a saucer fit it so the bottom of it against the backplate, when fitted the outer rim will sit away from the backplate.
#8 dyanetski
dyanetski
  • 65 posts
Posted 07 December 2008 - 10:12 PM
think that makes sense! do all 3 ridges end up in the recess of the cylinder?
#9 Ethel
  • 26,082 posts
Posted 07 December 2008 - 10:25 PM
Yes, either get one end in an lever the other over or put both ends in and squeeze it down with gas pliers or similar. Both ways need 3 hands :shifty:
