I Have A Hole!
7 replies to this topic
#1 chappy
chappy
  • 1,253 posts
Posted 09 December 2008 - 12:46 AM
as it says. i have a hole... its at the front of the floor panel on the drivers side, right before it joins the bit that curves up by the arch. (if that makes sense?)
its about an average finger diameter size..(well thats all i've pulled out for now)
whats the best option... just a patch over the hole? or a new floor panel?
cheers
sam
#2 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
Posted 09 December 2008 - 12:56 AM
depends on how bad the rot is!!!! if it is literally a hole, then a patch will be fine!!! you need to clean around it to see how bad it is first.
#3 chappy
chappy
  • 1,253 posts
Posted 09 December 2008 - 01:03 AM
how and with what? sorry for sounding stoopid :)
#4 chudley
chudley
  • 60 posts
Posted 09 December 2008 - 06:28 AM
i had same clean it up , rust treat area and then weld a small plate on it.
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 09 December 2008 - 06:39 AM
get your self a angle grinder with a wire brush attachment
#6 chappy
chappy
  • 1,253 posts
Posted 09 December 2008 - 10:21 AM
would one of those wire brush bits for a drill work too? what should i treat the rust with? that metal restorer chemical? or just take it all back to bare metal??
#7 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 09 December 2008 - 12:50 PM
a drill one will be ok but a grinder one is better
#8 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 10 December 2008 - 11:40 AM
To do a proper repair it will need taking right back to Bare metal, then weld a patch of fresh metal in.
