Engine Stand
redrascalmini
, Dec 09 2008 07:10 PM
4 replies to this topic
Posted 09 December 2008 - 07:10 PM
Im thinking of buying an engine stand while i rebuild my mini. Are they easy to bolt on? Is it work just using the crane to hold the engine.
Posted 10 December 2008 - 12:32 PM
Just using a crane is an absolute pain, the engine tends to spin around, and the crane isn't designed for it.
Engine stands can bolt in many places, favourite is fuel pump studs, quite easy if you get one with correctly spaced holes.
Dave
Dave
Posted 10 December 2008 - 03:05 PM
Dave
i have just bought one and also unsure on where to bolt it, will the two fuel pump bolts be strong enough? for the whole engine, including box and head?
EP
Posted 10 December 2008 - 06:58 PM
I've not done it myself, built mine on a pallet, however I remember a discussion about this before that mentioned using those holes.
Other advantage is nothing else bolts on round there.
Dave
Dave
Posted 10 December 2008 - 07:29 PM
mines bolted there
my machines uses the alternator bolts but has a jig to fit them
