Bmw Mini Windscreen Washers
11 replies to this topic
#1 newtown
newtown
    Starting My Mini Up
  • 1 posts
Posted 09 December 2008 - 08:26 PM
Can any one tell me how to get at the windscreen washer pump on a 2005 Cooper please?
#2 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 09 December 2008 - 08:36 PM
You'll probably get a better response on Mini2.Com as this forum is mainly for the classic/original Issigonis Mini.
#3 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 09 December 2008 - 08:59 PM
:strongsad:
#4 minili
minili
    Awesome and Flattering
  • 5,140 posts
Posted 10 December 2008 - 01:05 AM
mab01uk (<link) is TMF's most MINI knowledgeable member I believe - you could try sending him a PM :strongsad:
#5 sprintmini
sprintmini
  • 316 posts
Posted 10 December 2008 - 09:32 AM
Are you sure your washers are not just frozen?
#6 mab01uk
mab01uk
  • 12,555 posts
Posted 10 December 2008 - 07:36 PM
Open the bonnet. Remove the front drivers side black plastic wheel arch liner (several plastic clips and screws), behind the A panel you will see the washer bottle and pump. Push out from behind the plastic indicator repeater / side vent trim and you can then access the washer reservoir, pump motor & fixings. The washer motor runs in 2 directions to pump water to both the front and rear washers. The motor relays are hidden behind the main passenger compartment fuse box.
Let me know if you need any more help on this or as Minili said you can send me a PM on any BMW MINI topics.
#7 Hb_aircool
Hb_aircool
  • 14 posts
Posted 13 November 2016 - 01:41 PM
Open the bonnet. Remove the front drivers side black plastic wheel arch liner (several plastic clips and screws), behind the A panel you will see the washer bottle and pump. Push out from behind the plastic indicator repeater / side vent trim and you can then access the washer reservoir, pump motor & fixings. The washer motor runs in 2 directions to pump water to both the front and rear washers. The motor relays are hidden behind the main passenger compartment fuse box.Let me know if you need any more help on this or as Minili said you can send me a PM on any BMW MINI topics.
You wouldn't happen to know the part numbers at all for the washer pump for a 03 cooper please
#8 mab01uk
mab01uk
  • 12,555 posts
Posted 13 November 2016 - 08:06 PM
You can find all the part numbers for BMW's and MINI's online here:-
http://www.realoem.com/
(Enter your VIN Number or scroll down the menu and pick MINI R50 - Cooper - 2003)
Looks like part number:
03 PUMP WINDSHIELD WASHER   Qty 1   up to 01/2005   67128377429
Superseded by: 67126963854
Diagram here:-
http://www.realoem.c...&diagId=61_1485
Edited by mab01uk, 13 November 2016 - 08:18 PM.
#9 midridge2
midridge2
  • 1,794 posts
Posted 13 November 2016 - 08:29 PM
Are you sure the pump has gone, they get blocked up with the washer fluid/anti freeze going into a solid mass, try washing it out with hot water.
#10 Big Sam
Big Sam
  • 853 posts
Posted 13 November 2016 - 09:03 PM
#11 mab01uk
mab01uk
  • 12,555 posts
Posted 14 November 2016 - 07:24 AM
The technical advice has not changed and is still valid so why not revive an old thread if it helps?
This is one of the major advantages of Forums over Facebook groups which have already killed off or reduced traffic on many useful car forums like TMF........
#12 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 14 November 2016 - 10:52 AM
+1 well said Sir all these forum's need supporting or they disappear!
