Trying to make up a adapter for my flywheel puller.
I have lost the part that sits in the threaded end of the crank. What size is the hole in the end of the crank (with small clearance)
Also what is the flywheel bolt size please.
I could check but I am at work and I want to get the bit made this afternoon.
Thread/ Hole Size In End Of Crank
mk3 Cooper S
, Dec 12 2008 02:18 PM
4 replies to this topic
Posted 12 December 2008 - 02:18 PM
Posted 12 December 2008 - 02:35 PM
Just measured mine and there is a blank non threaded section at the top of the hole that measures 6.58mm deep from the end face of the crank. The blank hole is 15.56mm in diameter. I'm not sure about the thread but its an uncommon size i think. I think minisport sell a tap for it.
hope that helps you
hope that helps you
Posted 12 December 2008 - 02:40 PM
Thread is 5/8 x 16 UNS, bolt head is is 1.1/2" for diaphragm clutch and 30mm with captive lock for Verto..
Posted 12 December 2008 - 02:58 PM
Thanks chaps.
I should have mentioned it is Pre verto.
Posted 13 December 2008 - 02:31 AM
Um - use a crank bolt as the thrust piece... wind it in plenty (but obviously not enough to stop the flywheel from shifting) ... job done..
