Throttle Position Sensor
6 replies to this topic
#1 chudley
chudley
  • 60 posts
Posted 13 December 2008 - 04:46 PM
can anyone tell me exactly what the throttle postion sensor does on a spi cooper and what problems you will have if its not working,
#2 2lrminivan
2lrminivan
  • 276 posts
Posted 13 December 2008 - 06:20 PM
i think it tells the ecu what position the throttle is at and changes the CO mixture.it might cause it to run a bit lumpy but i am not sure.
do u think yours is not working
#3 Surfbluegarage
Surfbluegarage
    AKA mini_mad_daps
  • 1,547 posts
Posted 13 December 2008 - 10:46 PM
the throttle position sensor or tps should tell the ecu of the postition of the throttle... simple... but its also to do with the timing aswell i think.. cnt remember if its to do with the spi not havin a vacumn advance on the dizzy ... hhmmmm
#4 Ethel
  • 25,971 posts
Posted 13 December 2008 - 11:25 PM
The exhaust gas sensor usually adjusts the fuel/air ratio at steady speed but as it's on the wrong side of the engine it also needs the TPS to tell it to adjust when you accelerate - the exhaust sensor wouldn't know until after you've stuffed the engine full of lots more air.
If the TPS is faulty the car would be slower and rough under acceleration
#5 chudley
chudley
  • 60 posts
Posted 14 December 2008 - 12:09 AM
not sure it judders somtimes when acelerating
#6 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 14 December 2008 - 12:12 AM
It could be a temperature sensor, giving the wrong mixture/timing
David
#7 chudley
chudley
  • 60 posts
Posted 14 December 2008 - 12:18 AM
changed the lambda and coolent sensor so i will have to see what next
