Caliper Repair 12" Wheels
Posted 14 December 2008 - 04:14 PM
by that i mean the seals and pistons and would you have to split them to do this or can you do it with out spliting the caliper ???
Posted 14 December 2008 - 07:21 PM
Edited by taffy1967, 14 December 2008 - 07:21 PM.
Posted 14 December 2008 - 08:29 PM
Posted 14 December 2008 - 08:41 PM
Spliting them will cause no harm, there is a seal between the 2 halves which should be replaced, make sure its a proper part and not just an o ring as it is made of a special rubber which is resistent to heat and brake fluid.
It is a good idea to replace the caliper bolts aswell.
Posted 14 December 2008 - 09:32 PM
Posted 14 December 2008 - 10:38 PM
If they've been on a long time I would plan for worse case and have new pistons (stainless steel type) as well as the seal kit?
Posted 15 December 2008 - 07:25 AM
Posted 15 December 2008 - 01:30 PM
the only hard bit if i remember is putting the outer seal metal retainer ring in (i think there is a tool for it somewhere)
As already said any rust on the sides of the pistons and they will get stuck in the caliper.
Posted 03 April 2015 - 05:31 PM
Posted 03 April 2015 - 05:37 PM
When puting the o rings in the caliper which way round do they go or does it not matter thanks
Strictly speaking, the calipers do not use any o-rings. There are rectangular cross-section rubber seals and it does not matter which way they are installed. However, make sure the ring glands in the caliper where these sit are perfectly clean and free of rust and debris. When fitting the seals, lubricate them with brake seal grease or fresh brake fluid.
Posted 03 April 2015 - 06:22 PM
I always split the calipers, I just find it easier to clean them, inspect them and get the retaining ring for the wiper in.
90 times out 100 I've found the bridge seal can be cleaned and re-used, it's only when they have become contaminated that they need replacing, though they are not at all expensive when you can track them down.
Probably the hardest / trickiest part of the job is getting the retaining rings for the wiper seals back in.
I also use rubber grease on the seals before fitting the pistons back in, though you can use fresh brake fluid too, I just really hate the feel of that stuff on my fingers and I usually paint the calipers, so I'd rather fluid didn't end up on them.
Posted 03 April 2015 - 08:00 PM
Posted 04 April 2015 - 01:35 PM
Why mess around with brake components?!! Buy remanufactured calipers this way you know its right!
I can only speak for myself so my comments will not be applicable to everyone and their particular situation.
- Over here, there are only a handful of Mini specialists in the whole country from whom you could buy parts. New 4-pot pairs are upwards of $1000, Cooper-S style 7.5" calipers run about $300 for OEM, $200 for aftermarket (each). These vendors do not sell rebuilt (not that I've seen anyway) so you would have to have your calipers rebuilt locally. Rebuilding and repairing brake parts is not inexpensive because the shop doing the work is taking on a large liability.
- If you are not buying new, you are assuming the rebuilder did a better job than you can do. If you rebuild calipers yourself, you know exactly what was done and presumably... since it is your car... you won't be taking shortcuts.
As Spider said, the most difficult part of rebuilding a caliper is getting the dust seal retainer installed.
Posted 04 April 2015 - 06:27 PM
Yes, I do tend to agree, especially at these prices;-
http://www.bmcpartsi...collections/all
Posted 04 April 2015 - 06:50 PM
Ouch!
