What Should I Use To Flush Through My Heater Matrix?
6 replies to this topic
#1 chappy
chappy
  • 1,253 posts
Posted 16 December 2008 - 01:47 PM
So as it says..
i'm gonna be taking out my heater soon, and while its out i might as well give it a good service..
but what should i use to flush it through? i live in a hard water area so don't really want to fill it full of limescale. :dontgetit:
cheers
sam
#2 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 16 December 2008 - 01:59 PM
If the matrix is out you'll be okay flushing with cold water from a hose, but make sure that you put it somewhere to dry afterwards and use a corrosion inhibitor when you fit it back onto the car, (antifreeze has corrosion inhibitor in it).
You only get massive limescale build up when boiling water (in a kettle), or leaving/running it though something for a long time. Spraying through with a hose will more likely clean scale and rust out.
Dave
#3 Dev
Dev
    Fiat 500 'Ringer
  • 1,549 posts
  • Local Club: NF500
Posted 16 December 2008 - 02:02 PM
have you thought about using Domestos?
It removes unsightly limescale build up and kills all known germs DEAD!
seriously fast flowing water should clear it out easily enough
#4 chappy
chappy
  • 1,253 posts
Posted 16 December 2008 - 02:03 PM
sorry for sounding dumb... but
when i disconnect the matrix... its linked up to the coolant in the radiator isn't it? or is it somewhere else?
cheers
sam
#5 Ethel
  • 25,941 posts
Posted 16 December 2008 - 02:10 PM
cheers
sam
Yeah you can see the hoses come through the bulk head on the engine side. Expect up to 3 litres of water to come out if you don't drain the radiator first.
How about feeding your car a couple of calgon tablets? :shifty:
Only joking, but don't see why you can't use a heavy dose of bog cleaner in the matrix if you rinse it thoroughly afterwards.
#6 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 16 December 2008 - 02:12 PM
cheers
sam
Correct.
(and as a result not sounding dumb at all - you only learn by asking or doing).
Essentially the engine warms the coolant, and the coolant goes through the heater matrix, (where some goes to the air to blow into your car in the winter), and then the coolant goes to the radiator where more heat is removed.
Now cooler, the coolant goes round again.
Both heater and radiator work in the same manner - as heat exchanges.
hot water in, cold water out, cold air in, warm air out.
Hence why flushing with water is fine for both systems. And using 50/50 mix antifreeze to water is recommended to protect your cooling system, (and heater) against freezing up, corrosion and lime scale.
Regards,
Dave
#7 chappy
chappy
  • 1,253 posts
Posted 16 December 2008 - 03:09 PM
thanks for the replies guys, really helped me out. :shifty:
sam
