chocolate jazz
fiber glass panel repair
chocolate jazz
, Jul 29 2005 04:04 PM
3 replies to this topic
Posted 29 July 2005 - 04:04 PM
has anyone got any idea's on getting rid of a farly big crack in my firbreglass arch, i think it was sum jobo chav at college that did it no sure thou
any tips would be good cheers
chocolate jazz
chocolate jazz
Posted 29 July 2005 - 07:30 PM
you need to get some fibreglass matt and resin (halfords do a small kit for not a lot)
clean the area under the crack with white spirits until its nice and clean
give it a sand with 80 grit paper
then paint a coat of resin on
then apply the matt (pre painted with resin
paint another coat of resin on
apply another coat of matt but dry this time
use a brush to stipple (hit with the tip of brush) into the dry matt until the resin underneath soaks through
leave to dry / cure
then sand the crack out from the top to a V shape
apply P40 type filler and fill almost to the top
lightly sand when dry with 80 grit again
then skim with a good top coat filler (P38 style)
(or if you can get some gelcoat, fill the crack with gelcoat and cover with parcel tape to make it cure ... )
then sand , prime and topcoat
Hope that helps
Phil
leave to dry / cure
Hope that helps
Phil
Posted 29 July 2005 - 11:44 PM
use p.80 on the inside of the arch but use a lighter grade on the outside of the arch (p.180-p240) if it's too rough you can cut into it too deep and catch the matting in the panel your repairing, other than that it's a perfect guide! good luck with the repair!
Edited by bristolminimad, 29 July 2005 - 11:49 PM.
Posted 31 July 2005 - 09:42 AM
cheers for that guys will give it ago :tongue:
chocolate jazz
chocolate jazz
