Incorrect Speedo Reading
7 replies to this topic
#1 runkthepunk
runkthepunk
  • 312 posts
Posted 21 December 2008 - 01:58 PM
Hello
My engine is a 1.3 1989 metro unit and my car is a 1991 cooper running a standard set of dials
My speedo gives an incorrect reading but there doesn't seem to be a logical calculation to it i.e alway 10 MPH under/over
It seems to be correct up to about 10 MPH then gets steadily more off and will not go any higher than 45/50 MPH and I know I was doing 70 at one point on the motorway (sat nav)
Any ideas what could be causing this because its pretty annoying and I don't have a cigarette lighter adapter so my sat nav eventually runs out of battery
Rob
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 21 December 2008 - 02:43 PM
The speedo drives in the side of the gearbox are calibrated for a Metro with bigger wheels and a different speedometer, you need to change these to the correct ratios for a mini speedo...
use this to help...
http://www.guess-wor...nical/ratio.htm
you will need the tyre size, the final drive ratio in the gearbox and the tpm of your speedometer...
#3 runkthepunk
runkthepunk
  • 312 posts
Posted 21 December 2008 - 02:53 PM
use this to help...
Thanks for that really useful information I will have to get it set up properly before going on any long runs
Rob
#4 matt615
matt615
  • 923 posts
Posted 21 December 2008 - 04:08 PM
That sounds logical to me! It will be a percentage error rather than a fixed figure. For example if it's reading 20% over then at 5mph it would read 6mph - hardly noticable. However at 50mph it would be showing 60mph.
As said above, you need to change the speedo drive gears. This is a common problem when fitting Metro engines to Minis.
#5 runkthepunk
runkthepunk
  • 312 posts
Posted 21 December 2008 - 05:04 PM
Ah I see, I was expecting just a fixed figure difference as on my old mini the speedo itself was faulty and always read 10mph over speed
Is the task of changing the relevant parts difficult or not?
Rob
#6 matt615
matt615
  • 923 posts
Posted 21 December 2008 - 08:24 PM
If the engine is out of the car, they are very easy to change. With the engine in the car it's a bit more fiddly! You'll need to remove the radiator and the radiator side engine mounting. Then you need to jack that side of the engine up slightly to get access to the parts you need to remove.
#7 ZED
ZED
  • 287 posts
  • Local Club: WSMOC
Posted 21 December 2008 - 09:24 PM
i have the same problem, the easiest way is to follow someone and just make a mental noted where 30/40/50 etc
but recently i actually logged the mile for a journey i do regular, 45 miles to work. my mini showed 30 miles. which is 30% less, so my speed should be 30% more then the reading.
so when my speedp shows 20, i am doing 26,
50, i am doing 65
#8 runkthepunk
runkthepunk
  • 312 posts
Posted 25 December 2008 - 01:44 PM
Seasons Greetings!
Is this job (speedo drive change) something a local garage can do or is it I will have to attempt myself? I am not really good enough to attempt stuff like this without causing more problems so really need another option
Although another possibility I have heard about are Speedo Ratio Convertors basically inline units that change the speedo cable turns down to the correct amount. Does anyone else know about these and if I can get one for the metro engine to mini dials?
Rob
